PC-V Problem 2008 FLHTCU Help Needed
Old Mar 15, 2009 | 03:15 PM
AlphaBiker's Avatar
AlphaBiker
Originally Posted by HogDawg08
I guess the 3rd times a charm as the saying goes. Went out today, reinstalled everything and it started right up. Only thing I did different was to do as 09StreetGlider suggested and hit the start button as soon as I turned the ignition on. No pins were bent so I'm not sure what the difference is. Wish I knew what I did different as I now worry about it cutting off in the future when on the road...
I am happy to hear that. I just received my PCV yesterday and plan to install it this week. All I read was good things about it until I read your post and another that are having problems with it. I had the slow start problem with the PCIII on my '06 SG and I was hoping it was a problem that was resolved with the PCV. I also know that the bike will start right up if you don't wait for the engine light to go off. But even if I did wait for the light it didn't take that long to start, just about 3 or 4 seconds. I would like to hear how things work out for you after you get an opportunity to ride.
~eddie
Old Mar 16, 2009 | 06:04 AM
Pastor John's Avatar
Pastor John
HogDawg, keep us posted! The PCV for my '08 Road Glide is due this week and I am eager to compare experiences. Do you anticipate a Dyno tune, or do you think the FuelMoto map will be satisfactory for you?
Old Mar 16, 2009 | 06:07 AM
Pastor John
... and could you talk about the tight installation (pics would be great!). Did you install the unit as described in the instructions, or did you have to improvise another location since your bike is an '08?
Old Mar 16, 2009 | 06:37 AM
JustDennis's Avatar
JustDennis
I installed the PCV on my 08 EGS. There seemed to be plenty of room on my bike. The PCV is a pretty small unit. The only thing I noticed that could be described as tight is when you remove the battery to route the cable from the ECM to the right side panel. The cable is short and you have just enough room to reroute and reinstall the battery. After that, it fit right in. My bike doesn't have ABS though. I followed the instructions that Jamie sent for my bike. They looked like they were put together for the 08. Here's a picture just after I connected everything.
Old Mar 16, 2009 | 06:58 AM
Pastor John
Thanks, Dennis! Looks like the install should be easy. The cable that's coming out of the bottom of your unit - looks like a USB cable - what is that? Did you velcro the unit to the bike or use 3M double-sided tape?
Old Mar 16, 2009 | 08:05 AM
rjmac53's Avatar
rjmac53
glad the problem got solved...
Old Mar 16, 2009 | 09:37 AM
09StreetGlider's Avatar
09StreetGlider
The PCV comes with a 3M tape that locks together like velcro...only much stronger. I only used a small amount of it for the PCV and AT modules....used the rest for a key chain type garage door opener and the remote for my LED lights.
Old Mar 16, 2009 | 09:51 AM
JustDennis's Avatar
JustDennis
It was easy. That cable is a USB cable. I connected the supplied cable to the PCV and temporarily routed it up under the seat and to my right saddlebag. That way I can quickly open the bag, connect my laptop and look at the data from the PCV. I was checking the engine temp after various rides. Once I get tired of tinkering, I will just unhook it but for now it is very easy to connect the PCV to the laptop without removing the side cover.
I used the supplied 3M tape that locks like velcro. It is very strong and secures the unit very well. The bike runs and sounds great. I would recommend this upgrade and Fuel Moto to anyone.
Old Mar 16, 2009 | 11:23 AM
papifun's Avatar
papifun
[QUOTE=Pastor John;4712495]... and could you talk about the tight installation (pics would be great!). Did you install the unit as described in the instructions, or did you have to improvise another location since your bike is an '08?[/QUOTE
ya pictures would be great.. gonna order mine soon.
would like to see a step by step on how to place wiring for a SG from start to end.
pictures are like thousand words.. !
Old Mar 16, 2009 | 12:07 PM
JustDennis's Avatar
JustDennis
[QUOTE=papifun;4713609]
The instructions that came with the kit from Jamie were quite good with lots of pictures. There really is nothing to it. Just plug and play pretty much.
