PC-V Problem 2008 FLHTCU Help Needed
Old Mar 18, 2009 | 01:27 AM
  #31
drive2live2ride's Avatar
drive2live2ride
Default Here are the pics I promised:
These are pics of the auto tune modules. The pic with the single module shows how the first one goes and it fits perfect like it was made to go there. No velcro or zip tie on this one as the second module (shown in pic 2) holds it in. These are under the left side cover in front of the fuse box.
Attached Thumbnails PC-V Problem 2008 FLHTCU Help Needed-1.jpg   PC-V Problem 2008 FLHTCU Help Needed-2.jpg
Old Mar 18, 2009 | 01:46 AM
  #32
drive2live2ride
This first pic is of the modified (hacked) top caddy that I had to cut the corner off of to get the pc v connector to fit. There is just enough room in front of the battery for the connector, but the battery cover/ECM caddy hangs over the front of the battery too far and wont allow the connector to fit.
The second pic shows the connector in place. Look closely and you can see the modified caddy between the connector and the battery.
The third pic points out the connector, the pc v, and the auto tune modules.
Attached Thumbnails PC-V Problem 2008 FLHTCU Help Needed-3.jpg   PC-V Problem 2008 FLHTCU Help Needed-4.jpg   PC-V Problem 2008 FLHTCU Help Needed-5.jpg
Old Mar 18, 2009 | 02:01 AM
  #33
drive2live2ride
Here is a pic of the wide band 02 sensor installed on dresser duals. The sensor touches the top tranny cover between the starter and rear cylinder.
As stated in my original post, I am happy with the install overall. The bike is running great. I ran a couple hundred miles today, and it runs stronger than it did before. No regrets at this time. Have to remember that this is a RETRO kit for a 2008. The pc v was designed for 09's. The purpose of posting this with the pics is just to help inform anyone thinking about doing a retro install and help you know what to expect.
Old Mar 18, 2009 | 05:49 AM
  #34
Pastor John's Avatar
Pastor John
Terrific! Thanks for the pictures - my PCV should arrive tomorrow and these will be very helpful during the install.
Old Mar 18, 2009 | 11:12 AM
  #35
vtwinbmx's Avatar
vtwinbmx
Hey IClick which cam did you finally go with?
Old Mar 18, 2009 | 03:43 PM
  #36
iclick's Avatar
iclick
I found a sweet deal on a slightly used but perfect SE255 ($110), and after buying gasket kits, bearings, and bearing install/removal tools I'm out $285 for the entire job. Good investment, as this cam is exactly what I was looking for, which was to move my TQ and HP curves straight up with no shift to the right. IOW not a huge peak-HP gain but a meaningful boost in low-end and midrange TQ. If I were to hazard a guess I might say a 5-6 increase in both HP and TQ, and certainly worth the time and expense.
If you're looking for race cams that maximize peak-HP this won't be your best choice, but for heavy touring bikes that rarely operate above 4000 RPM's, this is the ticket.
Old Mar 18, 2009 | 04:07 PM
  #37
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
With the auto-tune, if you add a cam, do you need to reprogram it? Or does it self adjust?
Old Mar 21, 2009 | 08:55 AM
  #38
Volker's Avatar
Volker
5th Gear
[quote=drive2live2ride;4722171]This first pic is of the modified (hacked) top caddy that I had to cut the corner off of to get the pc v connector to fit. There is just enough room in front of the battery for the connector, but the battery cover/ECM caddy hangs over the front of the battery too far and wont allow the connector to fit.
Last edited by Volker; Mar 21, 2009 at 09:00 AM. Reason: placed message in wrong thread
pureoper
Nov 8, 2013 09:56 AM
rocksandgiz
Sep 19, 2012 08:18 AM
GPHDXLC
Jul 3, 2011 07:41 PM
dohadex
Feb 21, 2011 06:46 AM
shakak
Sep 26, 2009 08:53 PM
