Radio Bleedover :(
Old Mar 16, 2009 | 06:14 AM
WannaBuy's Avatar
WannaBuy
Question Radio Bleedover :(
Has anyone had problems with CB bleedover on their HK radios? I first noticed it driving home my brand new 09 UC last month up the interstate.
It seemed that as I came up on Semi-trucks their CB traffic would bleed over my FM.
I got a 3 hour ride in last week, mainly out in the country, and did not have any problems so I figured the original bleedover was just an anomaly.
I took the bike out yesterday and noticed that as I drove down certain roads with a lot of overhead wires I was getting interference in the form of a quick blip each time I would pass directly underneath an overhead wire. If I drove past a power station I got interference as well. I took note of certain trouble spots and found when I passed by the same spots hours later I got the same result.
So I stop at a friend's house to show him the new scoot and I turn on the radio only to hear two truckers having a BS session. This happened across all bands AM/FM/WB and XM! I leave his house drive 10 miles home no problems whatsoever.
I know the bike is under warranty but I thought if someone had run into this problem before I would try and fix it myself.
Old Mar 16, 2009 | 06:31 AM
wurk_truk's Avatar
wurk_truk
09SG here. Nope... haven't heard the problem that you describe. I don't have a CB radio option, though... Do you?
Take it back.
Old Mar 16, 2009 | 06:42 AM
slime_dog's Avatar
slime_dog
Turn off the CB if you are not using it. Normal CB bleedover could trip the squelch which will interrupt your FM/AM/CD/AUX listening. Normally, if you are running CB and a squelch event happens it will lower the volume on your current audio and allow you to hear the CB. It will then delay about .5 seconds before returning you to your selected audio input.
Old Mar 16, 2009 | 08:46 AM
dirtdobber's Avatar
dirtdobber
Most or at least many use amps (linear) for their cb radio. Not only will it boost the out put dramatically but causes bleed over. Even law enforcement radio's will do it. There are at least 2 types of bleed over 1) is bleeding from 1 channel (like slime_dog said) to another causing the cb it self to key; 2) bleeding onto the radio itself with the cb turned off. This can be caused by a couple of things, too much power (linear) and the linear is not matched properly.
As far as the power lines I get it sometimes. I plan to add a filter when I pull my fairing to install new speakers. It can also be cause by a faulty ground. That i will check at the same time.
dd
Old Mar 16, 2009 | 09:04 AM
n8dc's Avatar
n8dc
get a ham license and toss the cb.. problem cured You wont here the stupid trucker chatter and you can actually talk farther with 2 1/2 watts..
kc hog
2014-2024 Touring Models
14
Oct 30, 2014 07:24 AM
BM05FLHT
Aug 13, 2014 08:15 AM
Ghosttrain1
Oct 9, 2013 02:06 PM
dapster
Audio Systems
Jun 25, 2013 01:16 PM
JollyRogers
Apr 19, 2011 02:28 PM
