Anybody have a 07 Road King with
Big Sucker A/C
Reinhart true duals
PCIII
Stock everything else
Downloaded the map and bike seems to spudder just a little, also hear more valve noise, maybe normal just not used to new sound.
Try the Power Commander web site they have lots of canned maps. Vavle noise could be from the oil you are running too. I use Amsoil and i am very happy with it. Motor runs 20 degrees cooler too.
Well if it was me, I'd turn off the accel pump, as that map is pretty rich as it is.When you twist the wick, you may be adding to much fuel, causing your stumble. I have an 07 UC with pretty much the same set up as you. I ran that (812-020) map for awhile, and it did cool the engine down with higher afr's, but it was rich. My mileage was down to like 25 MPG's! I bought a Daytona twin scan plus wego set up. I made my own map with it. PM me if you want and I will email you a copy of the map I made. I still use the accel pump with my map, but only add 5% fuel at I think 85 sensitivity. That seems to keep the knock sensor happy in the warm weather.
I have similar setup with the difference of pipes. I have V&H big shot duals. I know the pipes are diff. but still true duals. I have a dyno tuned map and bike screams. If you want to try it pm me and I'll try to figure out how to email it to you.
