07 road glide right bag pops open
Old Mar 19, 2009 | 10:10 PM
gaser's Avatar
gaser
Red face 07 road glide right bag pops open
I have a 2007 r/g the right bag pops open as i run down the road . I instaled a new latch an it was no better . Any help would be great
Old Mar 19, 2009 | 10:20 PM
sonar_chris's Avatar
sonar_chris
Make sure that the cloth strap on the lid isnt getting suck between the lid and the bag. This will cause the bag to seem like its closed but it will pop open.
Old Mar 19, 2009 | 10:21 PM
1flhtk4me's Avatar
1flhtk4me
You can also keep it locked.
Old Mar 19, 2009 | 10:23 PM
gaser's Avatar
gaser
Thanks , i did check that an that's not it ,,,is it the plastic bag . I never had this with fiberglass bags
Old Mar 19, 2009 | 10:36 PM
1flhtk4me's Avatar
1flhtk4me
The latch should stay closed.Are you sure the hooks on the backside of the lid are engaged before closing the latch.
Another thing to check are the screws that bolt the latch to the bag and the lid are not missing and are tight.
Old Mar 20, 2009 | 06:47 AM
harleytuner's Avatar
harleytuner
When you open the latch nd look behind it (on the outside of the bag) you will see that the latch engages 2 small curved metal retainers at the bottom when the latch is closed, these spread open over time and the latches will pop out of place. Just take a small screwdriver and pry them up a little so the hold the latch in place and you should be all good to go.
Old Mar 20, 2009 | 07:01 AM
dowhat's Avatar
dowhat
Are your baggs vid black? If so I have your left one, mech did as harleytuner stated, before that I would keep it lock also.
Old Mar 20, 2009 | 07:23 AM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
I keep mine locked, solved the problem. Didn't like flying down the freeway with the open bag.
Old Mar 20, 2009 | 07:30 AM
1flhtk4me's Avatar
1flhtk4me
This has happened to my a couple times,only because some dumbass forgot to close the latch!
Old Mar 20, 2009 | 07:33 AM
IAMSWUTIAMS
Who was the dumbass?
