Torque #'s for rear shock bolts
Old Mar 21, 2009 | 06:21 PM
shekmark's Avatar
shekmark
Default Torque #'s for rear shock bolts
I ordered my service manuel from Zanotti, and it did not come in yet. Can someone please give me the rear shock torque number for my 09 SG. I'm installing Racetech Caddies shocks. Thanks
Old Mar 21, 2009 | 06:30 PM
Standard's Avatar
Standard
This is per SM for the 2007 touring bike...
Top Bolt is 33-35 ft-lbs with Blue (243) loctite
Bottom Bolt it 35-40 ft-lbs with Blue (243) loctite
That comes to you from the other side of this state.....Mt Laurel, near Cherry Hill.
Good Luck and Ride Safe O~`o
Old Mar 21, 2009 | 06:33 PM
txfxstrider's Avatar
txfxstrider
Old Mar 21, 2009 | 09:36 PM
shekmark's Avatar
shekmark
****, I forgot the loctite. I wonder if you really need it on shocks. There is a lock washer.
Old Mar 21, 2009 | 10:06 PM
Standard's Avatar
Standard
I am sure you will be ok, but if your **** like most on this forum (including me), then back them out and add the loctite.
I took off the shocks to put the rear tire on, instead of removing the mufflers, and never used the loctite.
Old Mar 22, 2009 | 06:08 AM
shekmark's Avatar
shekmark
I backed them out and put loctite on them. You were right.
RickK
Mar 17, 2022 09:20 AM
avneeshj
Oct 24, 2011 09:32 AM
stratplexi
Feb 24, 2010 11:34 AM
trozenhorse
Nov 19, 2009 08:17 AM
Hagar the Horrible
Nov 1, 2008 09:25 PM
