Your thoughts on engine trouble please.
Old Mar 21, 2009 | 11:20 PM
Lonewolf176's Avatar
Lonewolf176
Originally Posted by jdreed520
195 main/48 slow/3 turns out air fuel mixture screw
How far from stock is that?
Old Mar 21, 2009 | 11:23 PM
jdreed520's Avatar
jdreed520
I don't remember.
Old Mar 22, 2009 | 06:59 AM
Shank's Avatar
Shank
sounds like a port might have a bit of dirt or clog in it ,,,,these carbs are bone simple really,,,, take it apart and blow it out good with some carb cleaner and air,,,,and it wouldnt hurt to rejet go rich with bigger jets,,,they are cheap buy few and experiment to find the best fit,,,,,,,it doesnt take much of a clog to make things go south ,,,,let us know what happens
Old Mar 22, 2009 | 11:48 AM
hatchetman's Avatar
hatchetman
Just talked to a guy up the street. He pulled a kein off his cruiser when he bought it. He's gona look for it & I will bolt it on today i hope!
I will report my good or bad news as soon as I have it!
Thanks for the replies!!!
Hatch.
Old Mar 22, 2009 | 12:10 PM
Leftcoaster's Avatar
Leftcoaster
Most of the time with carbed Evo's all you had to do was richen up the idle jet and go up one or two steps on the needle and you were good to go with the baffles drilled out. They were lean on the bottom from the factory. This worked on mine anyway. You may have some varnish in the carb and a dose of Seafoam and an hours ride may cure your troubles.
Old Mar 22, 2009 | 12:48 PM
Serg06's Avatar
Serg06
I would go through the carb and make sure it is clean as a whistle. then check to see if it is rich/lean as suggested above. On carb bike any changes done to the exhaust system needs to be addressed at the carb as well. Remember by drilling a hole in the exhaust you change the setup from carb to tail pipe. It's easy to check so good luck.
Jaret Wilson
Oct 23, 2023 05:05 PM
shepardleec
Mar 30, 2016 07:29 PM
BIGDADI
Jun 1, 2008 02:34 PM
ae4782tt
Apr 7, 2008 08:03 PM
Doug45601
Feb 3, 2008 12:48 PM
