Fat Front Tire Question
Old Mar 22, 2009 | 06:35 AM
myxcape's Avatar
myxcape
Default Fat Front Tire Question
I'm wondering if a 150/80/16 would fit under a stock SG front fender?
Old Mar 22, 2009 | 07:02 AM
Jerry L's Avatar
Jerry L
I really can't answer your question, but have some experience with wide tires up front. I put a 4" wide 16" rim up front with a Metz 130/90 (this tire actually specs out at 142mm). I haven't actually measured the tire width on my rim. I have to "wiggle" the tire/wheel into the fender (I used soapy water) but once it clears the fender brackets, it clears and runs fine (there was some cussing and swearing once I learned it contacted, but continued on to see what would happen). You may be able to use that tire but may have to modifly the fender brackets some, or maybe put those fender lowering brackets on for more clearance (they don't look like they "bulge" out like the stock ones). Good luck!
Jerry
Old Apr 21, 2009 | 08:56 PM
ncbeast's Avatar
ncbeast
I would like to get a 21 front tire on my 08 road glide but do not want a skinny low profile tire? Is this possible?
vicsponjr
Aug 23, 2014 01:35 PM
JohnK-NJ
Dec 9, 2013 05:20 AM
nosparkoflife
Nov 25, 2013 03:36 PM
chappy99
Jan 15, 2012 02:56 PM
Doug S
Feb 21, 2011 12:02 AM
