New Shifter Linkage?
Old Mar 26, 2009 | 06:00 AM
Chuck1's Avatar
Chuck1
Default New Shifter Linkage?
I put a new shifter rod and better ends (heim) on last night. On the front lever I used a bolt and acorn nut and on the back lever, just a bolt. Lock washer behind acorn nut made it stick way out and looked clunky and I didn't see a need for a flat washer anywhere. Do you think just using blue Locktite without lock or flat washers will hold? I believe the stock linkage had a flat and lock washer on the front.
Old Mar 26, 2009 | 06:05 AM
dirtdobber's Avatar
dirtdobber
That's all I did. It has never came lose after 25,000 miles.
Old Mar 26, 2009 | 06:10 AM
JayStronghawk's Avatar
JayStronghawk
I never used any washers but made darn sure had plenty of Loctite.. an old Iron might vibrate loose without a lockwasher but see the need for it on newer ones...
Old Mar 26, 2009 | 08:45 AM
StreetGlideMedic's Avatar
StreetGlideMedic
+1 On What JayStronghawk said! Plenty of Loctite and it should hold just fine. That's all I did with mine.
Ride Safe, Mike
Old Mar 26, 2009 | 08:53 AM
smokindave's Avatar
smokindave
I used a chrome nyloc nut on mine.
Old Mar 26, 2009 | 10:17 AM
RenoGlide's Avatar
RenoGlide
Front: Buttonhead chrome allen thru the lever with a internal star washer & thin nut & blue loctite
Rear: Buttonhead chrome allen, 5/16-24 X 1.25 thru a chrome spacer 5/16 id X 1/2 od X 3/8 long, threaded into the rear lever with blue loctite. I used the spacer to lessen the severe angle between the front & rear levers.
Chrome Hardware is Gardner-Westcott from Reno HD, about $8.00 for all of it
Old Mar 26, 2009 | 11:34 AM
SteveB FLH's Avatar
SteveB FLH
+1...... I used a stainless nyloc nut though...
Old Mar 26, 2009 | 11:51 AM
nvsteve's Avatar
nvsteve
I did pretty much the same as RenoGlide above.
The spacer in the rear is about 1/2" on mine as my shifter rod is about 1" dia.
which puts the threads further from the tranny shifter.
Old Mar 26, 2009 | 03:47 PM
ezriderpgh's Avatar
ezriderpgh
bolt and acorn on front and stud and acorn on rear, blue locktite both ends
Old Mar 26, 2009 | 07:11 PM
Chuck1's Avatar
Chuck1
Thanks, sounds like it should be ok. I'll keep an eye on it for awhile.
