Making MP3 cd's NOT
Old Mar 28, 2009 | 11:53 AM
gregsworld's Avatar
gregsworld
The software NERO works well and is user-friendly. Pretty cheap too as I recall. Just make sure you are writing onto CD's and not DVD's. Big difference.
Greg
Old Mar 28, 2009 | 11:58 AM
RODEO's Avatar
RODEO
Originally Posted by willie37
I have been trying to make mp3 cd's for my 09 ultra and so far nothing will play on it but it will play on my lap top. I have the MP3 maker 14 deluxe and i just burned a dvd with mp3 files. Now i am afraid to try that.. I just played the dvd music cd on the lap top and it sounds great. Can some one help me out here.
Question, Are your songs stored on iTunes on your computer? if so, PM me because I know your problem and I know the fix. (Been there, done that.)..
Old Mar 28, 2009 | 12:05 PM
Cryptoboy's Avatar
Cryptoboy
Originally Posted by Thrak
Good day'
On your harley which cost a few pennies
don't listen to a lossless format with mp3
u loose top and bottom end which with music
like The Pink Floyd and King Crimson you will loose
much of the sound
compression makes music bland
JMHO
Doesn't really matter too much because most people can't hear much past the 128kbps anyways (CD Standard for that matter), and when you get on a bike going 75mph, you aren't going to hear it all anyways.
And to answer the OP's question, you can't play a DVD in a device made to handle CD's only. If you bought a high end aftermarket radio you might be able to, but the HD stock ones (and most of the reasonably priced aftermarket stereos for that matter) aren't made to handle DVD's.
Old Mar 29, 2009 | 11:34 PM
JohnScrip's Avatar
JohnScrip
Originally Posted by doc_cj
So far I've only burned a couple CDs. I'm using Nero and get about 25 songs on a CD. How are you getting 98 songs on a single 700meg CD?
Don't create an audio CD from MP3 files - Simply create a data CD. What Nero is doing is turning the MP3 data back to PCM data. That will limit you to around 75 minutes (at 44.1kHz/16-bit) as opposed to 800MB at whatever bitrate the MP3 data is written at.
Just ignore the fact that it's music and treat it as you would any other data.
Old Mar 30, 2009 | 12:22 AM
Donnylee's Avatar
Donnylee
Exactly!
Originally Posted by johnscrip
don't create an audio cd from mp3 files - simply create a data cd. What nero is doing is turning the mp3 data back to pcm data. That will limit you to around 75 minutes (at 44.1khz/16-bit) as opposed to 800mb at whatever bitrate the mp3 data is written at.
Old Mar 30, 2009 | 01:41 AM
CHGO5OH's Avatar
CHGO5OH
What about MAC users? I'm not getting any luck doing MP3's off Itunes.
Old Mar 30, 2009 | 05:01 AM
monkyman's Avatar
monkyman
I use Windows Media Player burned to data disc, Can get 140+ songs on a 700MB cd and play them no problem on my 09. I wouldn't think a dvd would work in a cd player.
Old Mar 30, 2009 | 05:28 AM
bdp's Avatar
bdp
https://www.hdforums.com/forum/touri...on-kardon.html
This thread started by zeus33 a few months ago was a big help.
Old Mar 30, 2009 | 05:57 AM
RODEO's Avatar
RODEO
If your music is stored on iTunes on your computer, here is the answer and fix:
I posted all the instructions here:
https://www.hdforums.com/forum/4245480-post33.html
It works!!
Old Mar 30, 2009 | 11:13 PM
JohnScrip's Avatar
JohnScrip
Keep in mind still that iTunes will write an audio CD - Not a data CD. One will give you around 75 minutes, the other has the potential for around 600 minutes of 'reasonable' (a.k.a. "good enough for riding") quality.
