rear fender tip
Old Apr 1, 2009 | 06:12 AM
BIG Y 2014's Avatar
BIG Y 2014
Default rear fender tip
thinking of putting lighted kuryakyn fender tip with plate relocation below tail light. what holds the stock tip and how do you remove it thanks. 05 roadking classic
Old Apr 1, 2009 | 06:24 AM
King FLH's Avatar
King FLH
I just put one on my RK. Two screws hold on the fender tip. If you have the lighted one, pull off the little red lens to get to the screws. Then take off the tail light lens to unplug it. There's a place under the tail light lens to plug in the new fender tip, (same place the old tip was connected to if you had a lighted tip stock) and it comes with a molded plug, all you do is push the wire ends into it, and they snap in place. Run the wire down and secure it in place. You have to curve bend yer plate to fit the frame.The whole thing took about 15 minutes.
TxAnthony
Jul 2, 2015 09:49 AM
paulies 07
Dec 5, 2012 04:38 PM
mattHD
Apr 15, 2011 09:17 AM
gtrplyr
Sep 19, 2010 12:39 PM
timvan
Mar 20, 2009 12:58 PM
