Itunes help
Old Apr 4, 2009 | 11:44 AM
YT's Avatar
YT
Originally Posted by jackinthebox
Thanks for the info. I guess Im just a little disappointed. I have I tunes and finally figured out how to burn cd in mp3 format so I was happy because I can get alot of music on one cd which is nice when cruising. So I decided to buy a few songs that I want instead of whole cds from the store and it wont let me use what I just paid for. I will try the tips you guys posted
Don't get too frustrated because it can be done - I do it all the time. You just have to first create a playlist with the tunes you want to burn and then convert them to MP3. You can do this using any number of free software out there. Google "MP3 Conversion Freeware" and tons of options will be there. I use a MAC to do this but I would be more than willing to help you out if you run into trouble, just send a PM... Good luck!
Old Apr 4, 2009 | 04:56 PM
sgdiesel's Avatar
sgdiesel
I don't believe this will work for music which has been bought and downloaded through ITunes as these are digitally signed. Just to be clear:
If you "Rip" a CD to Itunes, it will by default save it in AAC format which is Apples preferred format (and they would argue superior to mp3). If you browse through explorer to these files you will see they have an extension *.m4a - these can be converted exactly as described above and through numerous other methods all broadly touched on here.
If, however, you buy and download through ITunes these files will be signed and will have an extension *.m4p - and these cannot be converted to mp3. The reason is very simple, MP3 file format does not have the capability to digitally sign (lock) files. The whole reason ITunes / Apple have been successful in terms of their relationship with the recording industry is that they have demonstrated that downloaded music through ITunes cannot be pirated. You are entitled to transfer this music to 5 other machines (or burn 5 disks) and then that music will "expire".
So, in essence, to convert this to MP3 you have to burn a CD and re-rip as mp3, that does work.
Personally, I never download off ITunes anymore. Main reason being that there is virtually no cost saving and actually the sound quality I have found to be very disappointing. Itunes relies on an impulse buy of music, which we all fall for I guess, but if you can be patient buy the CD rather
Old Apr 4, 2009 | 05:14 PM
Mike5959's Avatar
Mike5959
http://www.m4p-mp3.com/?gclid=CLWhrN...FWNM5QodvkImXQ
Old Apr 4, 2009 | 05:17 PM
RODEO's Avatar
RODEO
Been there - Done that...
You dont need any extra software.
I posted all the instructions here:
https://www.hdforums.com/forum/4245480-post33.html
It works!!
Old Apr 4, 2009 | 05:46 PM
YT's Avatar
YT
I have to argue this... I do it using a program called Burn - its for a MAC but Im positive there is an equal freeware program out there for windows to convert the .AAC to .MP3 and it does just that, burns an .AAC directly to MP3. No re-ripping required! I only use itunes and Burn and have numerous CD's with 130+ songs on each. There are most definitely pros and cons to using itunes, the need for a conversion program being a con, but its not that difficult to do.
I do agree that it can not be done by using iTunes alone - as sgdiesel said - but it can with the right software which is usually found as freeware on the web.
Old Apr 4, 2009 | 06:59 PM
beary's Avatar
beary
Ipod shuffle is the easiest way to go.
Beary
Pothole914
Audio Systems
Jan 9, 2016 09:02 AM
Geezer glider
Audio Systems
May 18, 2011 03:15 AM
Hughey79
Audio Systems
Apr 9, 2011 09:18 PM
trackadaptor
Feb 6, 2011 02:02 AM
tda69
Mar 30, 2008 05:24 PM
