Help Needed
Old Apr 7, 2009 | 06:13 AM
rabbas's Avatar
rabbas
Default Help Needed
Guys,
I have a FLHRC 08.
Yesterday I installed LED front and back signal lights.
Shortly after I left, the key signal in the speed dial was on.
I parked the bike, turned it off and waited until the alarm system went into action then I operated it again. Same thing happened. Few kilometers down the road, the light went on again.
Does anyone has any suggestions??
I am thinking that if there something wrong with the electrical circuit (like over loading), the key light would go as soon as i turn on the bike and not few kilometers after.
What do you guys think??
Old Apr 7, 2009 | 06:25 AM
Hinzy's Avatar
Hinzy
It is throwing a code because of the load of the new bulbs.
Did you install a load equalizer?
If not it will throw the code because the led's draw less current
than the regular bulbs.
Look into a badlands load equalizer,
Let us know your progress
Hinzy
Old Apr 7, 2009 | 07:04 AM
rabbas's Avatar
rabbas
Hey Hinzy,
Thanks for the hint.
I did install load equalizers because the leds were flashing very fast when i installed them.
Old Apr 7, 2009 | 07:10 AM
hojones's Avatar
hojones
Have you tried taking main fuse out and putting it back in. Don't know if it will help but maybe the system needs resetting.
Old Apr 7, 2009 | 12:35 PM
myy2khog's Avatar
myy2khog
You need to add the additional load equalizer for the Security Equiped bikes. Kuryakyn makes one.
Old Apr 7, 2009 | 12:39 PM
HD Renegade's Avatar
HD Renegade
Just what he said, I had to do the very same thing with mine.
Old Apr 7, 2009 | 12:40 PM
Hinzy's Avatar
Hinzy
If the bulbs are now flashing normally then clear the codes,
your key light should then disappear.
Old Apr 7, 2009 | 06:16 PM
rabbas's Avatar
rabbas
Thank you Hinzy.
Yes they are working normally. How do I 'clear the codes'?
Old Apr 7, 2009 | 06:45 PM
Hinzy's Avatar
Hinzy
See this thread, should answer your question.
https://www.hdforums.com/forum/gener...odes-dtcs.html
Old Apr 8, 2009 | 10:52 AM
Hinzy's Avatar
Hinzy
rabbas
How did it go??
