Fork Oil Change
Old Apr 7, 2009 | 02:44 PM
steelhead's Avatar
steelhead
Default Fork Oil Change
Coming up on the 40k service on my '01 RKC and see it is time to change the fork oil. A quick glance at the service manual looks like this is a pain in the ****. Any thoughts from those that have done it? Hell, is it even needed? FYI- the '01 models have the air forks as well as the rear shocks.
Old Apr 7, 2009 | 04:06 PM
ffdharley3's Avatar
ffdharley3
It's not as tough of a job as it sounds. I have done the fork oil change a few times and can have my forks off the bike in about 10 min., whilst taking my time. Just read and understand and follow your manual. If you run into a tough spot ask your question on the board. These guys are great!
Old Apr 7, 2009 | 04:18 PM
dbird's Avatar
dbird
Looks pretty tough & special tools needed. I'll just take mine to the dealer.
Old Apr 7, 2009 | 04:50 PM
bluffalobob's Avatar
bluffalobob
I saw this on another forum:
Fork Oil Change
The no muss no fuss way to change your fork oil the HD manual leaves a lot to be desired.
Step 1- But a Mity VAC
Step 2- Remove bleed screw and insert plastic nipple
Step 3 – loosen fork spring nut and remove it is under a little pressure from the spring
Step 4- Start pumping the Mity Mite until all oil is out
Step 5- pour a couple ounces in the tube wait and then pump out
Step 6- Reinstall bleed screw
Step 7- Fill fork tube with the appropriate amount of oil
Step 8- Coat fork tube o-ring with Dowcorning 55 and reinstall
When done with both tubes go out and ride.
Old Apr 7, 2009 | 05:00 PM
garyhendley's Avatar
garyhendley
sounds easy for a road king but on the road glide the manual say take the
outside and inner fairing off this alone is a big job did it once it was a bear
you cant get to the top of the forks-ride safe
Old Apr 7, 2009 | 05:26 PM
iclick's Avatar
iclick
It's very easy if you have the right tools, perhaps a 15-min. operation for both forks. Get a vacuum pump of some sort, the cheapest around probably a Harbor Freight venturi vacuum for <$20 that attaches to your air compressor. You'll also need a piece of plastic tubing, but I don't have the specs. The correct size slips into the recessed area of the drain plug and holds itself in place for draining and filling. You fill from the drain plug using the tube by applying vacuum from the Schrader valve where you apply air for the forks.
1. Drain fluid
2. Remove pin from Schrader valve.
3. Attach vacuum pump and draw a vacuum
4. With tube attached to the drain plug recess and the measured amount of new fluid in a container, suck the fluid into the fork.
5. While vacuum is still applied, remove the tube and reinstall the drain plug.
This procedure was in my '96 service manual, so it should be in yours too.
Old Apr 7, 2009 | 05:28 PM
xxxflhrci's Avatar
xxxflhrci
No need to buy a special vacuum....I do mine with a shop vac.
Old Jan 16, 2011 | 08:45 AM
ThaGlyde's Avatar
ThaGlyde
Do i place the schrader valve back in when I'm done or do i have to purchase another? Can i use a siphon pump from auto zone and pump the oil back into the bike through the fork drain plug?
Old Jan 16, 2011 | 09:53 AM
steelhead's Avatar
steelhead
There is no reason to use the same one unless you are concerned about it leaking.
Old Jan 16, 2011 | 01:36 PM
iclick's Avatar
iclick
You unscrew and remove the inner portion of the valve using a removal tool available at auto-parts stores, then replace it when finished. After that you'll set the air pressure to your specs. The forks have a recessed area at the drain plug that fits a plastic hose. The size is the same as the old battery vent tubes, but I don't know the OD on these as it's been about 12 years since I purchased the tubing. It's a very easy procedure on these older bikes with air forks (<30 min. for both), and the procedure is outlined in the service manual, or at least was in my '96 manual. As mentioned earlier you'll need a vacuum source, and Harbor Freight Tools sells a low-priced venturi vacuum that works with your air compressor. That's what I used, which cost about $10, and it worked perfectly.
ADVNTR
2014-2024 Touring Models
25
Jan 17, 2017 07:37 AM
cerelious
Jun 20, 2015 03:11 PM
keith t
Jun 7, 2012 02:07 PM
cbo111
Mar 17, 2012 10:05 PM
eoluke
Aug 8, 2010 03:05 PM
