Ohlin shocks
Old Apr 8, 2009 | 07:18 AM
PROVIDER7's Avatar
PROVIDER7
Default Ohlin shocks
Anyone have ohlin shocks on a 08 street glide, stock HD shocks are 12" the ohlins I can get a deal on are 115/8" wondering if a lower than stock length ohlin will be worth the swapout also wondering about scrapping my bags. Whats everyones advice is a 3/8" shorter shock length that big a deal and do you think I'll get a better ride with the shorter ohlin's.
Old Apr 8, 2009 | 07:31 AM
Scorpion07's Avatar
Scorpion07
Ohlins are probably the best shocks you can put on a motorcycle. Super adjustable and the highest quality.
With that said - if they're not designed for your bike you shouldn't touch em.
Even though the overall shock length is "only" 3/8" shorter, the travel at the very least is more then likely different.
Not to mention spring, compression, and damping rates.
Old Apr 8, 2009 | 06:31 PM
PROVIDER7's Avatar
PROVIDER7
The olhin part#HD540 shocks are designed for the h-d FLH class bikes & I'm always reading on the forum about folks that have lower their streetglides 1" in the rear so was think'n a 3/8" shorter than stock shock wouldn't be a problem. Anyone out there that have olins or shock advice please chime in.
Old Apr 8, 2009 | 07:06 PM
NoTyme's Avatar
NoTyme
I had a pair cut down 1 1/2 " by Phoenix Customs and I wasn't quite happy with the dampening: I am going to sell them... Went back to stock shocks with a bit heavier oil.
Old Apr 8, 2009 | 07:11 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
had them on an old dirtbike back in the 70"s didnt even know they still existed.shorter means stiffer it is a trade off it will handle better but ride much firmer if theyre not stiffer youll bottom out too much.
Old Apr 8, 2009 | 07:21 PM
Twinrider's Avatar
Twinrider
I wouldn't go under stock length, these bikes have little enough ground clearance as is. I believe Fastharley (Howard) said he will be able to get standard length Ohlins.
Dazzauk
EVO
Jul 9, 2016 11:16 AM
bbqbrisket
Nov 30, 2011 07:11 PM
FXDXJimmy
Nov 19, 2011 01:59 PM
StreetGlider57
Mar 26, 2011 08:34 AM
PROVIDER7
Apr 8, 2009 07:11 PM
