brake shake
Old May 3, 2006 | 12:47 AM
eddybo69's Avatar
eddybo69
Default brake shake
Was stopping fairly hard today while riding 2 up used rear brake only for some reason. When I hit the rear brake the front end started a weird fairly violent shake. It wasnt like a high speed tank slapper just a shake. It seemed to be more front to back than side to side if that makes sense. I tried to recreate and realized that it does it every time I stop using rear brake only, which it unusual for me. I am not talking about sliding the rear tire just fairly agressive braking. While it is unusual that I would be doing this and it seems to only do it under about 5 MPH, I am still worried. Is this a sign of a more serious problem that may show up at high speed? Any ideas what may be causing this?
Old May 3, 2006 | 12:56 AM
eddybo69's Avatar
eddybo69
Default RE: brake shake
This was on an 06 ultra BTW
Old May 3, 2006 | 01:28 AM
RBJones's Avatar
RBJones
Possibly your rear rotor is warped and you don't notice it much when you're using both brakes because the front does most of the braking. If your front rotors were warped it would be a lot more serious. If it's worrying you, I'd have a mech look at it. I've heard that one thing that can cause warp is to brake really hard and then immediately park the bike. The area under the calipers remains hot while the rest of the rotor cools down quickly.
Old May 3, 2006 | 01:50 AM
eddybo69's Avatar
eddybo69
Thanks for the reply, sounds reasonable to me. In fact that was my first thought, but doubted myself since I only have 2500 miles on the bike. (just got it april 6) Just thought there may be some known issue I had missed with my search.
SCGamecock
Sep 11, 2019 12:54 PM
avasquez097
Aug 14, 2018 05:44 PM
2013superglideseattle
Jul 4, 2015 12:25 AM
Lincoln33
Dec 29, 2007 09:16 PM
takeiteasy
May 3, 2007 11:58 PM
