HD HID Headlight
So I treat mine as a custom feature, rather than a practical one. Now that HID kits are available I reckon a conventional twin bulb reflector is the way to go, as '05 Ultra' suggests, with HID for low beam. I also have HID in my car, but conventional high performance bulbs in main beam, as I believe HID doesn't suit high beam work.
I also recently fitted halogen driving lamps. With everything switched on I now have three distinctly different colours of light up front! Remember when halogens were the way to go? They are the dimmest and quite yellow, the HID very white, while the 100w main is quite blue. Ah well!
This is just passing lamps w/no headlight. You can buy this stuff over there & I can tell you how to make up your harnesses if you like. Again, not recomended for city traffic, use 4 1/2" headlights!
It is also a bi-xenon kit which means both low and high beams are fully HID. This kit turns dark roads at night into day!
I got mine in the high $300.00 range and it was worth every penny!
I would recommend this plug and play kit to anyone in a heartbeat.
Thanks!
