Flushing the oil system
Old Apr 10, 2009 | 12:58 AM
vharrig's Avatar
vharrig
Default Flushing the oil system
There are many of you that have MUCH more experience with engines than I. So, my question is, are the below steps dangerous to the engine, or a more common procedure that others actually use?
Flushing the oil system and changing oil
a. Run engine to operating temp 170-220 degrees
(rocker boxes too hot to touch)
b. Drain oil (Do not replace oil filter at this time)
c. Place new flush mixture (Diesel gas at a 1 to 1 ratio mixed with normal cheap 10-30w oil) in oil tank
(a total of 2 qts of fluid should be in the oil tank)
d. Run bike for 1 minute
e. Drain oil, Discard
f. Place new flush mixture in oil tank
g. Run bike for 1 minute
h. Drain oil, Discard
i. Place new flush mixture in oil tank
j. Run bike for 1 minute
k. Drain oil, Discard
l. Place 2 qts of 10-30w oil in oil tank (no Diesel)
m. Run bike for 1 minute
n. Drain oil, Discard
o. Change oil filter
p. Fill oil tank to proper level (according to Maintenance manual)
with oil you will be using for the riding season (high quality oil)
q. Run bike for 2-3 minutes, check and top off oil tank as necessary
r. Oil flush and change is complete
Old Apr 10, 2009 | 01:42 AM
OG1's Avatar
OG1
warm up, drain oil, change filter, fill with new oil, go ride. thats it. why are you concerned about getting every drop of old oil out?
Old Apr 10, 2009 | 01:44 AM
Casper's Avatar
Casper
Why? not being a smart a$$ but why would you do that unless something contaminated to oil in there.....I have seen some drain the oil and then start the motor and allow it to run for 20 seconds...pumps some more oil out, but I nave have...
Old Apr 10, 2009 | 01:52 AM
vharrig's Avatar
vharrig
I've seen those mechanisms on the internet for completely draining the oil/sludge and didn't "understand" if completely cleaning out the system really made a difference or not.
Old Apr 10, 2009 | 01:57 AM
street53glide's Avatar
street53glide
I would not introduce diesel or anything else into the engine. You can't get all of the old oil out unless you use the scavenger oil change system or something like it. I have installed one of these on my bike and it get all the old oil out. Is it really nessecary? I don't know, but it surely won't hurt!! After all, dirt is one of the main things that wears out an engine.
Old Apr 10, 2009 | 02:04 AM
DZLDR's Avatar
DZLDR
if it ain't broke...fix it till it is
just change your oil & filter and ride
Old Apr 10, 2009 | 04:14 AM
jpooch00's Avatar
jpooch00
Wink
+1 on that!
Old Apr 10, 2009 | 04:19 AM
Rafkin's Avatar
Rafkin
+1, flush is not necessary unless some contamination. If that concerned you can change the oil more often.
Old Apr 10, 2009 | 04:22 AM
xxxflhrci's Avatar
xxxflhrci
Nothing more than a waste of time, oil, and diesel, IMO.
Old Apr 10, 2009 | 04:26 AM
ko4qc's Avatar
ko4qc
I change all fluids every 2500 miles...overkill?..yes...do I worry about getting EVERY drop out?...NO...anyone who would put the diesel-gasoline-motor oil 'slop' in their engine and run it ...is... an idiot...JMPO...:>)
