SG owners
Old Apr 11, 2009 | 12:04 AM
Potato_Potato's Avatar
Potato_Potato
Originally Posted by eglinski
Does increased air PSI in the rear shocks, make the bike sit higher?
No - just stiffer.
Old Apr 14, 2009 | 12:06 PM
NHGlide's Avatar
NHGlide
Thanks again guys! I used your advice and put some air in and it rides like a dream!
Old Apr 14, 2009 | 02:29 PM
Thundercloud's Avatar
Thundercloud
Just be careful how you put the air in them. Buy the pump specifically made for them sold by HD at your dealer. If you use a standard air compressor you could damage your shocks.
Ride Safe,
TC
Old Apr 14, 2009 | 02:35 PM
SA315B's Avatar
SA315B
Default Danger - Danger - Danger
Ride Safe,
TC
If you use a standard air compressor you will damage the system!
Old Apr 14, 2009 | 02:37 PM
njdiver's Avatar
njdiver
I have 20 lbs in the rear shocks, because the Wheeldock operates better at that pressure. Enjoy your ride I Love Mine!!!!!!!!!!!!!!!!
Old Apr 14, 2009 | 07:26 PM
JohnScrip's Avatar
JohnScrip
I'm at around 23-25, also originally because of the Wheeldock - Which didn't help, it still doesn't quite touch the ground (bit I digress).
The side-effect was that the ride was great. It's "stiffer" but it's much more reactive in a good way.
Old Apr 14, 2009 | 07:29 PM
StreetGlideMedic's Avatar
StreetGlideMedic
Absolutely use you manual...find the correct PSI for your riding style...one up...two up! Adjust accordingly!
If all else fails...always use manual! And when ya get a few bucks...buy the service manual! that is the bible for us!
Good Luck with your new ride! Mike
Old Apr 14, 2009 | 07:38 PM
street_glider's Avatar
street_glider
Ride Safe,
TC
+1 on the HD suspension hand pump - it's seems expensive, but worth every penny when trying to get the pressure on such a small volume of air just right. You won't regret it.
Old Apr 15, 2009 | 10:39 AM
Maxcustody's Avatar
Maxcustody
Not a plug for HD, but make sure to use the correct air pump. If you use a compressor you will blow the seals out.
I saw someone already said this.
Old Apr 15, 2009 | 10:53 AM
jrsmith_80's Avatar
jrsmith_80
I was told by my salesman that I could just use a hand operated air pump, it this not true? He specifically said that he would not waste the money on the pump if you have a hand pump already? I have no problem getting the HD pump but did not think it was needed at the time of purchase. What makes the HD pump better then a regular ole hand pump?
