Doherty Power Pacc
Old Apr 10, 2009 | 06:27 PM
maineultraclassic's Avatar
maineultraclassic
Default Doherty Power Pacc
I'm looking for some ideas for my problem...........
My Doherty PowerPacc with Powervents is weeping oil from the breather bolts. The plastic washers are worn, stretched, and broken and are not doing a very good job of sealing. So I need to replace them and I would like to know if anyone has found anything that works better and is more durable at a local hardware store or autoparts store.
I know I can order new ones from Doherty, but they are just going to fail again.
Thanks,
Steve
Old Apr 10, 2009 | 07:52 PM
molsen's Avatar
molsen
Trying to remember what I did when I had them. If I am not mistajen they are quite thin. A quick off the top of my head would be a thin fiber washer, but it may not look correct. Drag specialties sells a bag of them cheap. They are really design to last only 1 assembly and disassembly.
Old Apr 10, 2009 | 08:01 PM
XTrooper3936's Avatar
XTrooper3936
Harley uses rubber o-rings and they work quite well.
Old Apr 10, 2009 | 08:09 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
+1 for the o ring idea.
Old Apr 10, 2009 | 08:54 PM
BadPiggy's Avatar
BadPiggy
Best fix is copper or aluminum crush washers.
I use them, never had a problem.
Old Apr 10, 2009 | 09:33 PM
maineultraclassic
I'm going to hit the hardware store and auto parts store this weekend and see what I can find to fix this problem. They are very thin cheap plastic, and I've installed/removed a few times......so they are toast now.
Steve
Old Apr 10, 2009 | 09:38 PM
BadPiggy's Avatar
BadPiggy
Steve
Copper or aluminum crush washers can be used over 'n over 'n over...........
Old Apr 10, 2009 | 09:43 PM
twenty_over's Avatar
twenty_over
6th Gear
I have a Doherty PowerPac as well, I did not like the plastic washers that came with the kit so I bought some H-D ones for the Screaming Eagle A/C Kit. They have worked out just fine and don't leak, sorry but I don't have the part #.
Good Luck...
twenty_over
Old Apr 10, 2009 | 09:44 PM
PhilM's Avatar
PhilM
Chris...
How 'bout copper or aluminum crush washers?
Old Apr 10, 2009 | 09:52 PM
maineultraclassic
Where is the best place to get them?
Steve
