With all this talk about whether to polish rotors or not. Just how are they polished? Is there a right and or wrong way? Is there an easy or hard way? What works? Thanks!
Well I just happen to have a couple D/A sanders for body work so I started with 80 grit then moved to 150 then 220 then 320 then i wet sanded with 400 1000 and I think i used some 1500 also.. then i used my auto buffer with regular compound finished with some WENOL.. Mine look pretty good.. If you have a nice commercial Baldor buffer and all the right compounds and rouge you can make em look like chrome .. Like i said im happy..
I used sandpaper on an attachment that goes on an electric drill. I used 320-2000 grit. I did the entire rotor. After mastering not ripping your paper on the sharp edges, you can polish out a rotor side in about 45 minutes.
Same here. Started at 80 grit and ended with either 1500 or 2000, can't remember. All on a palm sander. Doesn't take long at all and the results will impress you!
Do the rotors not go back to crappy looking once u use the brakes a few times??
Yes they do on the braking surface .. Yup i polished the whole rotor.. (question was asked also)
Im gonna let you all on a little sumpin on the rotor bolts.. No i used wenol for mine and I chucked up each bolt in the cordless drill and with the Wenol (i used the blue they make a red tube also) i dabbed a little on a rag and ran the drill at hi speed and with a little pressure on the bolt heads it polished the cad plating right up . Dont get crazy or it will take it off.. Mine look sweet and it was as Jesse James says a (FREEBIE) Now since im out of a job id appreciate a dollar for every bolt you polish up cause the of the free tip and even at a buck a bolt its cheaper than the chrome stuff ? I think ... Oh ya mothers mag polish works too on the rotors and the bolts but the Wenol is the cats azz and I think someone has one of them for sale here also .. Yup its dead too... I just dont know what you could use to drive it for polishing
