Rear Pulley
Old Apr 16, 2009 | 09:43 PM
rags's Avatar
rags
Default Rear Pulley
Does anyone know the difference between a 40117-00 and a 40217-04 pulley. I have a 2005 Ultra and parts books calls for the 40217-04. Both are 70 tooth and 1 1/8". I don't have the wheel off but they look the same. If I can verify they are I am going to send the loose pulley to the chrome shop. Thanks in advance.
Old Apr 16, 2009 | 09:50 PM
dawg's Avatar
dawg
40217-00 SPROCKET ASSY, REAR BELT DRIVE, 70T, BLK $165.00
40217-04 SPROCKET, FINAL DRIVE, 70T $171.00
One says black and is cheaper, that's all I can tell by running them without having a look see
Old Apr 17, 2009 | 09:59 AM
Dennis Murawski's Avatar
Dennis Murawski
I have just removed the rear pulley from a cast rear wheel assembly from a 2005 Ultra. The part no. is 40117-00. If you need pics, let me know. Also, (shameless plug time) the pulley is available in the classified touring section.
Dennis
Old May 30, 2010 | 10:53 AM
shortride's Avatar
shortride
I'm looking for a stock final drive sprocket for a 2000 FLHT for a friend.
Old May 30, 2010 | 12:43 PM
DTTJGlide's Avatar
DTTJGlide
If the 00 pulley is 1 1/8" it didn't come on a touring bike as they used a 1 1/2" belt, it may be for a softail or something. You'll just have to measure the offset on the pulley to see if it will work, the bolt pattern is the same.
Old May 30, 2010 | 02:55 PM
BLKBAGGER's Avatar
BLKBAGGER
Yeah this thread makes no sense to me. the last two numbers are the year release date. 00 bikes were 1 1/2" belts. Yet Dennis says he just removed a rear pulley from his 05 with 00 part number?
ke5rbd
Mar 9, 2013 08:50 PM
gavdar
May 18, 2011 05:17 AM
moose thecat
Wheels/Tires
Oct 6, 2010 05:17 AM
rotorcrazy
Apr 10, 2009 04:51 PM
johnnyhumble
Dec 25, 2008 09:49 AM
