Flh-Flhx windshield
Old Apr 18, 2009 | 10:42 AM
eglinski's Avatar
eglinski
Question Flh-Flhx windshield
Can someone please give me an accurate measurement of the width across their windshield,
across the outside, over the curve, and just above the screws and fairing lip?
I have installed a new Wide Open Customs detachable fairing on my RK.... the shield that I ordered with the fairing (5 1/2") is not tall enough.
I am looking to order a Clarks wide windshield and need to be sure it's compatable.
Thank you
Old Apr 18, 2009 | 10:51 AM
eglinski's Avatar
eglinski
Sorry,
I also need the measurement from the middle screw to either end screw...outside, along the curve.
thanks again
Old Apr 19, 2009 | 10:21 AM
eglinski's Avatar
eglinski
Anyone?, can chime in here....
I really need the screw to screw measurement
Old Apr 19, 2009 | 10:41 AM
DaltonHD's Avatar
DaltonHD
Sorry, misread the post..I have an 04 RC with no fairing..Don't know if the #'s would be the same.
Old Apr 19, 2009 | 11:27 AM
RenoGlide's Avatar
RenoGlide
For all HD "batwing" fairings used from 1996-2009:
The linear (flat) measurement from the centerline of the center hole, to the centerline of either outside hole is 10.062 or 10 1/16". In a linear plane, the outside holes are raised above the center hole to compensate for the curvature as installed .
Im not familar with Wide Open Customs fairings... but if they do not accept the OEM HD windshields then their measurements are of their own design and may not be compatable with Clarks shields which I know are made to HD specs.
Hope this helps......
Old Apr 19, 2009 | 11:51 AM
eglinski's Avatar
eglinski
Thanks Jim,
The shield that I have is installed already, and when I measure over the curve on the outside, over screw heads I get 10 1/4" so, I think that may be real close.
also, the Harley fairing bra (new) fits perfectly, on the fairing screw holes (a good sign)
I know that the WOC fairing shield is only 21 1/2" wide..... so some trimming and mods will be required
EasternSP
2014-2024 Touring Models
17
Sep 30, 2017 04:02 PM
oakmossy
Nov 22, 2014 10:27 AM
jcstale
Jul 29, 2013 09:41 AM
maryvillept
Jan 19, 2011 04:15 AM
cragdweller
Nov 28, 2009 01:28 PM
