deby cover removale
Old Apr 18, 2009 | 04:04 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
Default deby cover removale
is it a must or can u drain the oil and add a measured amount.and can it be done without removing the pasenger floorboard.
Old Apr 18, 2009 | 04:09 PM
dawg's Avatar
dawg
Do you mean do you have to remove the derby cover to fill the primary? If it is a pre 07 then no you don't have to, you can fill it through the chain inspection cover. If it is an 07 or later then you have to remove the derby to refill. It can be done without removing the passenger floorboard but it is tricky unless you put on soos' passenger floorboard spacers like I did. This allows me room to get in and get that one pesky bolt out without having to remove the board.
Old Apr 19, 2009 | 01:54 PM
Fireman44's Avatar
Fireman44
Or if you have adjustable rear foot boards.
Old Apr 19, 2009 | 03:47 PM
nvsteve's Avatar
nvsteve
I can't on my 07 Ultra.
Old Apr 19, 2009 | 03:51 PM
scotty3's Avatar
scotty3
Do it properly and adjust your clutch while you have the derby cover off.
Why cut corners? If it is time to change the primary fluid then it is time to adjust the clutch.
saxfiend
Aug 6, 2012 10:39 AM
sr_smyth
May 2, 2011 08:48 AM
sparky_mo
Dec 13, 2010 04:16 AM
aggiejason
Aug 30, 2010 03:59 PM
jerboys
Oct 6, 2007 06:23 AM
