vibration
Old Apr 19, 2009 | 08:48 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
did it sit on concrete all winter on the jiffy stand? flatspot on the left side of tire?
Old Apr 19, 2009 | 09:09 PM
DrE's Avatar
DrE
It sat on asphalt with jiffy stand down.....I've had it out several times this season and have put about 250 miles on it. Yesterday was about 75 degrees ambient and I had put 20 miles on it at varying highway/backroad speeds and still noticed the vibration....
Old Apr 19, 2009 | 09:14 PM
Mick's Avatar
Mick
I had a similar problem on my 06 Standard.
The bike would vibrate slightly and make a low level RRRRRRRRR noise , only while taking a long left hand sweeping turn at 50 mph or above with the wife on the back.
Knowing that the dealer wouldn't ever be able to simulate the problem , I figured on trying my own idea.
My thought was the belt was getting too tight in this exact situation.
The belt should get slightly looser while taking a sweeping right hand turn because of the rear pivot shaft bushings deflecting under that particular force.
I ordered the Harley belt deflection gauge and when I checked the belt , it was at the tight end of the spec.
I adjusted the belt to the looser end of the spec and it seemed better if not gone all together.
This is a very small change , but it seemed to help on mine.
I never had the problem when riding by myself , only with a passenger.
Maybe a possibility.
Mick
DIESEL-FUMES
Jun 24, 2019 05:19 AM
rdkng103
2014-2024 Touring Models
Nov 12, 2018 07:57 AM
flash1964
Jun 3, 2018 12:50 AM
goose222
Apr 21, 2016 04:42 PM
64deville
13
Nov 8, 2014 07:08 PM
