hi, great site. been lerkin for awhile, but now i have a ? my turn signal flasher dosen't work (blinkers wont blink, just stay on) my ? is wheres the flasher. thanks in advance 1990 flht. kevin
There are 2 flashers. One for the directionals and one for the 4-ways. They are mounted under the dash in the upper right hand corner under the tach. The wires are quite short and they are mounted in a spring clip like a circuit breaker.
Reach up under the right front corner of the cowl and the directional flasher is generally the one most inboard. Flip on your 4-ways and you'll be able to feel which one it isn't.
thanks for the replys. im heading to the barn to check it out. sooie, did i say somthing to offend you? i dont understand your reply. thanks again. kevin
the flasher on my 85 was rectangular shaped. i went to an auto parts store and got an automotive flasher #552. only a couple of bucks. cheeper than the hd brand.
just in case someone else has this prob. you dont have to take of the ferring, dont even take the headlight off ( i did all that ) turn front end to the left, on the right down tube between the triple trees is where its wiretied, black module type thing 4"L x 2" w 1/2" thick 1 plug going to it. $130. my bike is a 1990 flht. hope this might help somone in the future. thanks again for all the help. kevin
