Where are the cam experts?
Old Apr 25, 2009 | 11:16 AM
1Reaper's Avatar
1Reaper
Default Where are the cam experts?
I am going to have some cams put in my 08 street glide. My indy says about 6 hours labor. Is that about right?
Also, I have samson big shot slip ons with load(race) barrels, very open breather exhaust, big sucker, PCV, what is the best aggressive cam for me to run?
Thanks in advance!
Old Apr 25, 2009 | 11:47 AM
Donnylee's Avatar
Donnylee
If your staying 96 the SE 204s and 211s work very well overall. There are tons of aftermarket choices. I make 95HP and 105 TQ with the SE211s at roughly 90 feet ABSL.
On a trip to Laughlin I pulled one bike length on a friends 103 SE255 bike up to 95MPH out in the Nevada desert. There will be tons of opinions, and you have tons of choices based on where you want to focus the power.
Old Apr 25, 2009 | 01:07 PM
Puttnutt24's Avatar
Puttnutt24
I'm having cam's installed this coming Tuesday. I have '09 Street Glide. Martin Bro's 2into1, Big Sucker intake, FuelMoto's PC-V and I decided to go with Wood's TW-6-6 Cams with the +4deg advance gear. I've heard nothing but good things about these cam's.
6 hrs is about right. My shop is charging me 4.5 but I'm bringing him my bike with no exhaust, tank and stripped. I'll do as much work myself except tear into the cam cover..
.......Rich
Old Apr 25, 2009 | 02:36 PM
iclick's Avatar
iclick
Thanks in advance!
That's probably about right if you re-use the stock pushrods--otherwise I'd say four hours if the tech is accustomed to the job. It took me about a full day to do mine using the stock pushrods, but I hadn't done the job before and was going very slow and deliberately. The exhaust is the biggest hassle and removing the rocker covers and plates came in a close second. The actually cam change, gear and chain alignment, etc. were not time consuming and even the inner-bearing swap is quick when you have the right tools. I did a write-up here.
I chose the SE255's because of their excellent low-end and midrange power. These are not high-HP cams that would be at their best on a dragstrip, but they do very well with heavy touring rigs with tall gearing for riders who rarely exceed 4K RPM. If you want to race or hold bragging rights at the pool hall for high HP numbers it is not a good choice.
Old Apr 25, 2009 | 03:43 PM
capnlovr's Avatar
capnlovr
I put some Head Quarters Cams in my 08 SG. I love them, very very happy.
Old Apr 25, 2009 | 05:22 PM
1Reaper's Avatar
1Reaper
Thanks so far, keep the info coming.
Old Apr 25, 2009 | 05:48 PM
StreetGlideMedic's Avatar
StreetGlideMedic
+1 to this! everywhere I turn I hear this is an excellent add if you're gonna remain at the 96! Even the techs at My dealership say if I'm not wanting to upgrade to more CI or Compression...go this route!
Ride Safe, Mike
Old Apr 25, 2009 | 11:48 PM
gregm's Avatar
gregm
I just had a set of Headquarters 034G cams (with S&S gears, K&N air cleaner & PCIII) installed in my '05 EGC. It took about 6 hrs to install using new adjustable push rods (so the top end didn't have to be removed). After Dyno tuning, the engine ended up @ 78.3 hp & 88ft/lb tq. The 034G cams are about as big as you can go without having to replace the valve springs. Compare cam specs to be sure you're going to get the improvements you're looking for. The 034s worked for me, with Python slip-ons I get excellent performance & good sound.
Good luck.
Gregm
Old Apr 26, 2009 | 02:29 PM
Puttnutt24's Avatar
Puttnutt24
Anyone here with any experiance with the Wood's bolt-in cams (TW-6-6)? You guy's have me second guessing myself Rich
Old Apr 26, 2009 | 05:51 PM
jag1886's Avatar
jag1886
My dealer charged me 3 hrs labor to put my cams in this last winter, when you invest in the adjustable push rods, it cuts the labor in half.
At first all the local indy's and the Harley dealer tried to charge me for 6 hrs which is what they charged to do it on the older engines which where harder to work on: I called them on it then they did the right thing and reduced the time to what it actually takes.
I think the HQ500 cams work great.
