Chrome Cleaning
Old Oct 24, 2009 | 08:26 AM
peddler's Avatar
peddler
Originally Posted by vette8494
Call me STUPID!
You're STUPID is not the correct reply????? I can say that because I just did the exact same thing the other day.
Originally Posted by beaucoup_dinkydow
might want to try using a copper penny to scrape with.
copper is softer than chrome and won't scratch it.
If you're counting on the copper in the penny being softer than chrome you better look for a penny minted before 1982. If your Lincoln Memorial penny has a date before 1982, it is made of 95% copper. If the date is 1983 or later, it is made of 97.5% zinc and plated with a thin copper coating. Where else can you find this kind of valuable info??????
Old Oct 25, 2009 | 08:55 AM
DocHarley's Avatar
DocHarley
Originally Posted by frenchbiker
No it doesn't. 0000 steel wool is perfect for chrome. Dip the piece of steel wool in wax and it will remove all baked stuff with no scratches whatsoever.
Been using it for years, even on custom bikes. Oven cleaner works too but it destroys paint so it has to be used very carefully.
My bad. You'd think after all my years I would have learned "NOT" to believe everything I hear.
Did some reading on the net and 0000 is great for removing scratches on chrome. Duh!
Old Oct 25, 2009 | 10:37 AM
HarleyWood's Avatar
HarleyWood
The problem is that some (most) guys dont have the patience it takes.
You can rub right through chrome with 0000 wool even with wax and then the next question will be " I have a copper looking spot on my pipes, what is it?"
If its just a small spot, soak it with oven cleaner for a few minutes and then gently scrape the fibers with a penny
moderation..patience
good luck
Old Oct 25, 2009 | 10:42 AM
Faast Ed's Avatar
Faast Ed
I have put permanent swirls in chrome with .0000 steel wool before, bad enough to warrent replacement.
Old Oct 25, 2009 | 02:35 PM
HarleyWood's Avatar
HarleyWood
Originally Posted by neonhomer
but it is a stop gap measure, as it rusts again.
Unless anyone knows of a better way to remove surface rust from chrome.... Yeah yeah I know, once it rusts its going to always rust... but I am trying to slow it down.
not necessarily true in all cases.
rust is like a cancer, you can't just remove the visible surface rust, you have to kill it.
wash the parts with something that has phosphoric acid in it (like lime away or driveway cleaner, use gloves)..and soak it a bit..let in penetrate to where the rust is breeding...or if you don't want to mess with chemicals use vinegar...it will kill rust too, it just takes longer.
Then polish it back up with your favorite chrome polish
Old Oct 25, 2009 | 07:13 PM
Faast Ed's Avatar
Faast Ed
I didn't know that about vinegar. Nice tip!
TOMMYBLAZIN
Oct 30, 2016 09:00 PM
bigdogx
Apr 6, 2011 07:49 AM
NewHarleyGear
Motorcycles For Sale
13
Jan 28, 2011 09:07 AM
djyoung214
Nov 15, 2010 01:39 PM
JohnG3
EVO
Jul 28, 2010 09:58 AM
