brake disk info needed
Old Apr 26, 2009 | 08:38 PM
halfbreed's Avatar
halfbreed
Default brake disk info needed
I am replacing the 40 spoke wheels on my 2001 Road King with 9 spoke cast wheels which I purchased via this forum. Although the T40 Torx screws were very difficult to remove from the front wheel, I am not having much success removing the T45 Torx screws from the rear wheel. In fact, I broke my new T45 torx socket trying to get the screws out, but I will persist and eventually get all out. No problem with the bolts securing the belt sproket to the wheel. My question is should I use a thread locker when I attach the belt sproket and brake disks to the wheels? When I removed the original, I did not see any evidence of thread locker, but they were a bear to remove. I read through the official factory service manual and did not read anything about using thread locker, which i usually use on just about everything I put on my Harley. And, if I should use it, should I use the red or the blue. My next question is should I consider replacing the brake discs. I only have 24,000 miles on the bike and the disks appear to have a lot of mileage left on them, but while I have everything apart, etc..
Thanks for your replys and I get a lot of great information off this forum. Halfbreed
Old Apr 26, 2009 | 08:53 PM
xxxflhrci's Avatar
xxxflhrci
Use a little heat from a propane torch and those bolts will come right out....The heat will melt the locktite.
The factory bolts have pre-applied Loctite. That is why the manual says to replace them. I always just brush the threads and put them back on torqued to spec with blue Loctite applied.
24k miles isn't too many miles on your rotors. You can use a dial indicator to measure them if you are curious. The minimum thickness is written on each one.
Old Apr 26, 2009 | 08:57 PM
bagman1's Avatar
bagman1
Been there done that! What I found to get them off is use a good torx bit preferably the kind that are 3/8" drive and are forged in one piece (Vermont American). You may get by with a socket type with replaceable bits, but I found the first kind not to break.
Secondly and very important use a long breaker bar or ratchet, I used a 30" bbar and they come off like butter.
Throw all your old bolts away, including the pulley bolts. They are a one time use only. I used red locktite on the pully and blue on the rotor, but I think the book calls for red on both. At 24k your rotors are still good, but you should mic them to be sure.
Old Apr 26, 2009 | 11:56 PM
Harleypingman's Avatar
Harleypingman
Halfbreed, what Service Manual are you reading? I ask because my 2004 HD SM says to re-use the five sprocket bolts, apply two drops of red Loctite to each, and torque to 55-65 ft-lbs.
As for the brake discs, my manual says to use new screws "after three use cycles." A couple of drops of blue loctite won't hurt anything, but isn'at mentioned in my manual.
The brake discs/rotors have a minimum thickness engraved/embossed in them near the hub. Mic them to be certain you're okay; 24K you sould be but may vary based on your braking and riding style.
Good luck with your project.
Edit: Halfbreed, misread your OP and see you have a 2001 RK and edited my post accordingly.
Old Apr 27, 2009 | 07:58 AM
bagman1's Avatar
bagman1
Originally Posted by Harleypingman
Halfbreed, what year and model bike do you have, and what Service Manual are you reading? I ask because my 2004 HD SM says to re-use the five sprocket bolts, apply two drops of red Loctite to each, and torque to 55-65 ft-lbs.
You might want to check with the dealer, the 07 book says not to reuse them. They may have updated their procedure since 04. Besides a new set of bolts is cheap compared to machine work if ever needed. There are issues on the rear pulley/IDS bolts loosening and breaking. Again cheap insurance
Old Apr 27, 2009 | 10:05 AM
halfbreed's Avatar
halfbreed
Thanks for your replies. I did go back to my service manual and flound the information I needed. I guess I just missed it the first time. I have also measured the thickness of the disks and they are within the suggested measurements. I will use a propane torch to heat the remaining screws for removal. I appreciate your time and information. Halfbreed
Grog
Wheels/Tires
Apr 2, 2015 04:02 AM
jackhis
May 24, 2012 05:07 PM
das56170
Jan 7, 2011 10:30 AM
Crusher
Jan 5, 2011 08:43 AM
jm1211
Jan 30, 2009 01:02 PM
