arc amp owners
Old May 4, 2009 | 12:38 AM
zippo2's Avatar
zippo2
Default arc amp owners
What wire or color wire are you connecting the remote wire of the amp to so the amp turns on when you turn the stereo on. I have had the bike on and off testing various wires with a test light and I get several lighting up. Does the amp stay on all the time when the bike is running even if the stereo is off.
Old May 4, 2009 | 03:19 AM
ripper43's Avatar
ripper43
The blue wire is connected to the cig lighter, the amp only comes on with the key switch.
Old May 4, 2009 | 04:49 AM
Gtsdesigns's Avatar
Gtsdesigns
you could also use your aux switch too... there are many ways to do it... cig lighter is one, also, as someone else has suggested... in my how-to thread, i think i indicate which wire i used for acc. off the factory radio harness....
Old May 4, 2009 | 06:38 AM
blueride's Avatar
blueride
Default Remote wire
I connected the remote power turn-on to the cig. lighter. As mentioned above, amp turns on with the key. Seemed the simplest connection point, as I couldn't find the black-blue power lead in my wiring harness.
Old May 4, 2009 | 06:50 AM
StreetGlideMedic's Avatar
StreetGlideMedic
+1...for the average person doing this work...the blue wire is usually the easiest to find. Altho I know Gtsdesigns has the experience and definitely knows how to wire for sure! Do a search and check out his installations!
Good Luck and ride safe, Mike
Old May 4, 2009 | 11:21 AM
zippo2's Avatar
zippo2
Thanks you guys for responding. I'll check in to all these options, I get a little impatient and want to get this system going but want to do it right also. I have some extra speakers that I want to put in the lowers and they are a 3ohm speaker and the uppers are 4 ohm I hope thats not a problem.
SoloRider67
Audio Systems
Apr 12, 2018 10:00 PM
Payner
Audio Systems
33
Mar 14, 2018 03:41 PM
Ron C
Electrical/Lighting/Alarm
Mar 12, 2015 08:44 PM
scooter_trash_1
Audio Systems
Mar 11, 2013 09:50 AM
dontdropit
May 17, 2009 11:00 AM
