Is this normal??
Old May 7, 2009 | 02:52 PM
Dallastx's Avatar
Dallastx
Default Is this normal??
I never paid attention I guess. Grease where the front fork goes into the frame.
Old May 7, 2009 | 02:55 PM
kingkingking's Avatar
kingkingking
you mean around the steering head bearings?
Old May 7, 2009 | 03:07 PM
mkbrower's Avatar
mkbrower
I just had my forks off and no grease. Dry as a bone. I sprayed some WD 40 to add a little lubrication when I put the forks back in.
Mark
Old May 7, 2009 | 03:19 PM
WillyHD's Avatar
WillyHD
Since I just got my EG I haven't looked. Do the baggers have a grease nipple for the head bearings like my FXST? I'll have to look tonight.
C
Old May 7, 2009 | 03:56 PM
iclick's Avatar
iclick
First, WD40 isn't a lubricant--it is a penetrant and shouldn't be used to lubricate anything except maybe door hinges and other minor uses. Second, the forks have no exterior lubricating points, although it is normal for some grease from the steering head to settle in that area. It the steering head was greased correctly at the 1000-mile service there should be some grease evident from the top or bottom of the steering head. On a new bike there will be none, as the factory's idea of greasing the steering head is just enough to last 1000 miles. The first service will require a lot of grease to fill the head.
Old May 7, 2009 | 04:20 PM
Dallastx's Avatar
Dallastx
Makes sense to me..
Old May 7, 2009 | 04:39 PM
ElectraDave's Avatar
ElectraDave
My '03 Electraglide has a nipple on the steering head. Manual says to grease at regular intervals; I'd have to look at owners manual to tell you for sure but I think every 1000 miles. HTH.
Old May 7, 2009 | 04:50 PM
WillieC's Avatar
WillieC
Default 2006 SG has a grease nipple
Old May 7, 2009 | 05:07 PM
layne01's Avatar
layne01
After going through my own bike, I would have to say that the factory does not waste any money on grease. Nothing, nada, bearings need grease!
Old May 7, 2009 | 05:13 PM
jag1886's Avatar
jag1886
I had so much grease on my front forks when I first got it that the heat front the motor was melting it and it was running out the left side of the tree and down the leg, making it look like it had a leaking leg seal.
My 07 has a grease zert on the neck.
