Jack clearance
Old May 9, 2009 | 06:12 AM
big_e78's Avatar
big_e78
Default Jack clearance
I just bought a jack that is 4.5 inches high. Apparently my Road King sits at about 4 inches (when on side stand). What is the best way to get the jack under the bike?
Old May 9, 2009 | 06:17 AM
RoadKingYeo's Avatar
RoadKingYeo
Stage III
You could always try and ride one tire up on a 2x6 and see if that would give you the clearance you need?
Old May 9, 2009 | 06:22 AM
cromagnon's Avatar
cromagnon
Do you still have the box? Don't be one jack off.
Bring that thing back. You should get some responses on what the best jack is for your King.
I did the same thing, bought a cheaper jack at Northern Tools but just like yours, too high. I went and got one of those Craftsman yellow jacks that go down real low under the bike. It's not the best, but works real well as long as you RTFM.
Old May 9, 2009 | 06:23 AM
spence222's Avatar
spence222
Inflate your tires to 100psi....just kidding, My Ultra is lowered 2" front and rear so my jack was a tight fit too....I'd stand on the right side of the bike and stand it up off the kickstand and slide the jack under...tight fit but it does work.
Old May 9, 2009 | 06:41 AM
eglinski's Avatar
eglinski
Thumbs up
+1.... on the Sears Craftsman "yellow" jack Its aluminum, light weight.. works very well
Old May 9, 2009 | 06:44 AM
ojgp's Avatar
ojgp
Often a short 2 x 4 or 2 x 6 placed under the jiffy stand will let the bike still stand by itself and upright the bike just enough to slide the jack under it .
carltex's Avatar
carltex
+1 Roll the jack from the right side, pull bike up off jiffy, and jack away. My procedure with the Street Glide.
Old May 9, 2009 | 06:57 AM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
I used to recommend the Sears Yellow Jack, until mine broke last week. I replaced it with a J&S Jack. Wish I had bought this one first. It's very similar to the Pit Bull.
http://www.jsjacks.com/
Old May 9, 2009 | 07:03 AM
Notgrownup's Avatar
Notgrownup
+1 on the 2x6 i bought the jack for $69.00 instead of the high dollar one....that was for my sporty...works fine for the EG.
Old May 9, 2009 | 01:17 PM
TheBagger's Avatar
TheBagger
I just push the bike up off the stand, hang on to the bars with one hand and push the jack under the bike with the other. It's a balance act but I have no problem with it, been doing it for years.
