Lowering the rear.
Old May 11, 2006 | 10:03 PM
Prw3's Avatar
Prw3
Default RE: Lowering the rear.
"Keep the Load Forward — Place the load over, or in front of, the rear axle.... Mounting loads behind
the rear axle can affect how the motorcycle turns and brakes. It can also cause a wobble." Page 33 of the MSF handbook
I agree that keeping additional weight in front of the rear axle provides the best handling but this has nothing to do with lowering the rear end by 1 inch. Regardless if the rear end is at factory height or one inch lower the handling is going to be effected with excessive weight behind the rear axle. The question that folks have brought up is if lowering the rear end only causes a noticable change in handling and the concenses is no or not enough to cause concern.
Old Jun 24, 2006 | 04:01 AM
kirtapp's Avatar
kirtapp
Really considering lowering the rear of my ride with the Solow kit. Just curious what they mean when they say " this product is simple and not a permanent modification."
Is it exactly that? Not meant to be permanent?
Old Jun 24, 2006 | 05:28 AM
Matt8643's Avatar
Matt8643
They mean that it is simply a piece of metal that moves the the bottom shock eye mounting location lower and slightly to the rear so as not to change shock angle. If you remove this pieces of metal you can then mount the shock back into the original location with no problems-just like stock again!! In other words, it doesn't permanently change anything and can be easily undone.
Old Jun 24, 2006 | 05:39 AM
kirtapp's Avatar
kirtapp
ORIGINAL: Matt8643
didn't think of it that way.. Makes sense.
Thanks
Old Jun 24, 2006 | 06:23 AM
ZookHD's Avatar
ZookHD
I agree with the guys that suggest lowering the front and rear. You want the bike to sit even and ride even. Im 225 and the wife is 125. My bike is lowered in the back by about an 1 1/4 inches using the Burley lowering (shock relocator) kit. The front is lowered about the same using the Harley lowering springs. If your bags rub using the Burley kit, it wont be by much. Just use a heat gun or space the bag out a little. Ben
[IMG]local://upfiles/13976/B2A920E1DC3A4BEE83C9838A1513569E.jpg[/IMG]
[IMG]local://upfiles/13976/A59BA1F1A1D747668F3709A84183355E.jpg[/IMG]
[IMG]local://upfiles/13976/8465AF57BF274645AD6D1C235CB61136.jpg[/IMG]
Old Jan 18, 2007 | 11:14 PM
scarygt's Avatar
scarygt
ORIGINAL: ZookHD
Good thing you attached those thumbnails they really helped me see what you were talking about! How about some bigger pics please! [sm=chairshot.gif]
Old Jan 19, 2007 | 12:30 AM
Redhead1's Avatar
Redhead1
Street Glide and Road King Custom are lowered in the rear only from the factory.
Old Jan 19, 2007 | 12:45 AM
Bigredone's Avatar
Bigredone
Call the folks at Works Performance Shocks. Tell your weight, passenger weight, % of time you ride 2 up, and how much you want to lower the seat to the ground. They will build shocks to fit your exact need. No guessing and you will love the ride.
Old Jan 21, 2007 | 07:40 PM
Viejo's Avatar
Viejo
Just my 2 cents worth. the center of gravity does not change by raising or lowering front or rear. It only changes with physical movement of weight forward or aft of the current COG. The rear end does not gain weight because it is lower, the laterial CG will remain the same. What will change is the CG will be closer to the ground, which will give much better handling at slow speed and in turns. If the COG changed with raising the nose or lowering the rear, then the CG of airplanes would change with takeoff and clilmb. They do not. Just my 2 cents worth.
Old Jan 22, 2007 | 04:55 PM
ultraultra's Avatar
ultraultra
If you lower the back without lowering the front, you will probably run out of adjustment on your auxiliary lights, and they will only be good for pisin other drivers off, or coon hunting.
