Lowering the rear.
Center of Gravity, lights, etc. If you don't spin a wrench and have no first hand experience with modifying bikes and riding modified bikes just stop and give the poor guy a break.
Lowering just the rear of your glide 1" or 1.5" with either lowering blocks or shorter shocks is done all the time and the factory also does it. The ride is a little worse and parts scrape a little easier in the turns, but that's it. Any change to the rake and trail measurements are so small, they will not be noticable or dangerous and will not effect your center of gravity, adjustment of your lights, etc...
If your a short guyor you are going for the "slammed" look, then lowering the front the same amount as you lower the rear will work as well.
There is some serious Crazy Talk goin' on in this thread...
Just my 2 cents worth. the center of gravity does not change by raising or lowering front or rear. It only changes with physical movement of weight forward or aft of the current COG. The rear end does not gain weight because it is lower, the laterial CG will remain the same. What will change is the CG will be closer to the ground, which will give much better handling at slow speed and in turns. If the COG changed with raising the nose or lowering the rear, then the CG of airplanes would change with takeoff and clilmb. They do not. Just my 2 cents worth.
I loweredour UCback only 1/2" with lowering blocks, it's noticeable and my pipes hit drives when exiting that they did notdo before, can't imagine going 1 1/2" lower.
[IMG]local://upfiles/3544/A0349125E9954E7E85A80DEF7AEBAEEB.gif[/IMG]
