Replacement Horn
Old May 14, 2009 | 09:42 AM
Cohiba_Joe's Avatar
Cohiba_Joe
Default Replacement Horn
Hey To All......
The stock Harley horn on my '05 RKC has taken a dump. In fact it sounds like it's taking a dump when you try to use it. I was curious as to any good replacement horns out there that will allow the use of a horn cover designed for the stock horn. I figure if I'm going to replace the horn assembly I'd like to get something a bit louder.
Thanks for any info,
Brian
Old May 14, 2009 | 09:46 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Try checking your grounding point for it to see if it fixes it. This happened to mine and the motor mount bolt on my softail that was also the grounding point for the horn had disappeared. New bolt, like a new horn!
If you want a new horn that is cost effective and loud check out the WOLO air horn. There are ways to fit it under the horn cover, but you can get it in chrome and it looks fine.
Old May 14, 2009 | 10:52 AM
Road Ranger's Avatar
Road Ranger
Agreed, check your connections. Mine was doing the same thing, sounded like a sick duck or something. I disconnected the horn and cleaned all the connections hooked it back up and it works fine now.
Old May 14, 2009 | 10:58 AM
jberg's Avatar
jberg
Mine does the same thing and it's only a few months old! Dealer will fix or replace under warrantee but a louder horn is a better idea. Best deal on a real loud one is from Stebel. Chrome one for just over $40. Too bad it won't fit under the oem bell.
Old May 14, 2009 | 11:01 AM
Sammi's Avatar
Sammi
FIAMM Freeway Blaster Low Tone. Part # 72112.
Fits under stock cowbell.
Around $15 at most auto parts store.
Bought mine at Advance auto and haven't heard the sick goose since.
Just a bit louder than the stock HD horn btu works every time.
Sammi
Old May 14, 2009 | 12:25 PM
socalrk's Avatar
socalrk
Default Horn
If you just want a stock horn I have several. Will send ya one for the cost of shipping.
Old May 14, 2009 | 12:49 PM
cadman311's Avatar
cadman311
I went with the Stebel, Wolo Chrome or bad boys black it the same thing harley sale for more with a logo on it. You try amazon or E-Bay I bought Wolo chrome last week for less then $30 with shipping. I use amazon is around $41. plus shipping.
Old May 14, 2009 | 12:52 PM
cadman311's Avatar
cadman311
There are horns at your auto parts store that will fit under the cow bell than is louder than stock but not as loud as the air horns.
Old May 14, 2009 | 12:58 PM
TheShrink's Avatar
TheShrink
I just went with the Mini Beast.
Old May 14, 2009 | 01:00 PM
cadman311's Avatar
cadman311
