Bub True dual help
Old May 14, 2009 | 07:16 PM
craney01's Avatar
craney01
Stage III
Default Bub True dual help
What tool(s) or configuration of tools did you guys use on the lower exhaust flange nut for the rear cylinder on your Reinharts? This is tough. I called the local harley shop (Elk Grove, Ca) today and the tech guy laughed out loud. He said "Whatever works, it's a bitch". Any suggestions????
Old May 14, 2009 | 07:38 PM
FLTR2008TRIKE's Avatar
FLTR2008TRIKE
I got crows foot socket to use. Found using that with a swivel and extension works. You can get the sockets at Sears
Old May 14, 2009 | 07:44 PM
Taterdog's Avatar
Taterdog
+1 on the crows foot.
Old May 14, 2009 | 07:47 PM
Taterdog's Avatar
Taterdog
Craney, the biggest problem I had was getting the P clamp to line up for the bolt. This is what worked for me, and it worked like a charm.
Old May 14, 2009 | 07:53 PM
madmatt's Avatar
madmatt
Loosen the top bolt then you can try turning the headers so you got more room for the lower flange nut. Worked for me but you must not force it or you'd risk breaking of the bolt. Do the reverse when you're putting the headers back on.
Old May 14, 2009 | 07:58 PM
truckerdead's Avatar
truckerdead
I used a 1/4 inch drive with a swivel 6 point 1/2 socket and a long extention. Came at it from above the right side passenger floorboard
Old May 14, 2009 | 08:00 PM
Bad Pig's Avatar
Bad Pig
I had no issues with mine....I just installed the BUB 7's TDs. I could actually get a socket (1/4" drive) on mine with a good swivel....not sure of the difference with the rhineharts though.
Old May 15, 2009 | 08:23 AM
nocages4me's Avatar
nocages4me
The main problem I had was getting the clamp to tighten down around the muffler so that it didn't leak. To get the headers to the heads I just left everything super loose until I got them on then worked it back to the mufflers.
Gasitman
Exhaust System Topics
Feb 12, 2015 02:35 PM
casadelray
Dec 19, 2009 08:35 AM
PFD232
May 9, 2008 04:34 PM
JF7044
Jul 20, 2007 05:13 AM
GOSTAZ
Sep 19, 2006 09:03 PM
