shifter linkage advice
Old May 19, 2009 | 06:18 AM
msbhvn's Avatar
msbhvn
Default shifter linkage advice
I was replacing the stock shifter linkage with cover to a HD stainless steel linkage. The diagram of the old linkage on the instructions shows the ends inverted directions yet the one I took off had the bolts going from the outside in. The diagram for the new placement also has them going inverted. If I do that I would have to extend the linkage and placing it on the inside of the front shifter lever to miss the jug and it seems close to the engine but placing it on outside of the shifter lever seems to have it running a little out of line but maybe not enough to matter. Appreciate any help.
Old May 19, 2009 | 06:25 AM
HB's Avatar
HB
Do which ever looks good and still functions.My .02
Old May 19, 2009 | 06:42 AM
glide2005's Avatar
glide2005
Not sure what linkage your talking about, but if its the stock linkage that comes from Harley. Do yourself a favor and replace the linkage joints with stainless steel hime joints.
Old May 19, 2009 | 07:42 AM
dawg's Avatar
dawg
Put it on the outside, bolt from the rear. See pic
Old May 19, 2009 | 08:02 AM
glebo's Avatar
glebo
I just replaced mine with a hime joint one. I did what the directions said, put it on the inside of the front shift lever. It's close, but it doesn't hit the jug. With the linkage outside the lever, it looked "off angle", but I'm sure it would work just fine either way. As long as doesn't bind on anything you'll be good.
Old May 19, 2009 | 08:30 AM
oldmanwayne's Avatar
oldmanwayne
+1 The instructions are wrong. When I followed the instructions- the linkage hit the jug.
Old May 19, 2009 | 08:34 AM
msbhvn's Avatar
msbhvn
I should have added the part number is 33840-09 on an 06 Ultra. Thanks for the replies.
chkywuky
Sep 25, 2013 07:33 PM
c50plus
Dec 16, 2011 12:36 PM
RadarRider
Jul 6, 2011 08:16 AM
fatboy5150
Jan 28, 2008 03:51 PM
XRP
Aug 21, 2007 09:58 PM
