Question about Primary Fluid...................
Old May 19, 2009 | 05:47 PM
soos's Avatar
soos
Originally Posted by Sammi
I don't have an answer for you but do have a piggy-back question.
When you drain the oil plug does that also drain the primary?
Sammi
This should help.
Attached Thumbnails Question about Primary Fluid...................-drainplugsfordummies.jpg   Question about Primary Fluid...................-primary-drain-plug.jpg
Old May 19, 2009 | 10:11 PM
Retrop's Avatar
Retrop
Default Filling primary with new oil
After draining out the old oil from the primary, refill with fresh oil until the oil just touches the bottom of the clutch basket. The clutch basket is that big round hub that is inside the primary case and houses the clutch. I will take something around a quart. If too full by a smidgen it won't hurt anything but neutral can be a little harder to hit and it will not shift as well. So, refilling is not 'critical" but if you want it to shift like it is supposed to do refill until the oil reaches the bottom of the clutch basket. It is hard to see so get out your flashlight.
thevirginian
2014-2024 Touring Models
Jul 14, 2015 12:12 PM
crash1
May 25, 2014 04:57 PM
lbj
Oil Archive (no new posts)
Feb 28, 2012 11:29 PM
kelton3
Apr 28, 2008 06:12 PM
LT753
Feb 29, 2008 07:34 PM
