Question about Primary Fluid...................
Old May 19, 2009 | 12:38 PM
mwriggs's Avatar
mwriggs
Default Question about Primary Fluid...................
I recently changed the fluids on my '06 EGC. The dealer said 1 quart should do it on the primary, but I thought I had remembered reading somewhere about the fluid should come up to the bottom of the clutch's???? Mine didnt, so should I add more until it does?
Old May 19, 2009 | 12:48 PM
Sammi's Avatar
Sammi
I don't have an answer for you but do have a piggy-back question.
When you drain the oil plug does that also drain the primary?
Sammi
Old May 19, 2009 | 12:53 PM
modes's Avatar
modes
Sammi
No, seperate plugs for motor, tranny, and primary. Primary plug is on the bottom of the primary facing out away from the bike.
Adam
JonnyD's Avatar
JonnyD
Sammi
They have their own drain plugs. One for each, 3 total.
Old May 19, 2009 | 12:54 PM
Homebrew101's Avatar
Homebrew101
I believe 1 quart is all you need for an '06
Sammi
no, there is a separate plug to drain each plus another for the tranny.
Old May 19, 2009 | 01:08 PM
n8dc's Avatar
n8dc
yupper 06 1 qt... works fine..
Old May 19, 2009 | 02:14 PM
iclick's Avatar
iclick
FWIW, TC96's require 38 oz., or at least my '07 SG does.
Old May 19, 2009 | 02:39 PM
beary's Avatar
beary
I never paid attention to the level. Maybe I should, but I always just add a quart in my 02 and 38ounces in my SG.
Old May 19, 2009 | 03:56 PM
Roadking Cal's Avatar
Roadking Cal
ONE quart ONLY!
If you over-fill the primary, by even "just a little", you risk over-dampning the clutch basket & plates. It's a "semi-dry" set up, and too much fluid on those parts lets things slip and slide way more than you'd want.
When in doubt, read your factory service manual. If you don't have one, get one. Sure, they're kinda spendy, but there's no substitute for the information in them. Get the chrome AFTER you get the manual....
Old May 19, 2009 | 04:14 PM
petemac's Avatar
petemac
1 quart in the '06 primary is all it takes.
