Fork oil change after 1K?
Old May 21, 2009 | 01:07 PM
1of2's Avatar
1of2
"Moderator"
Default Fork oil change after 1K?
I plan on doing my 1K service myself.
Harley suggests changing the fork oil at 1K and every 50K.
I can understand the 50K but does anyone know why they want to change it at 1K? I plan on changing it because it is recommended. I'm sure there is a good reason for it. Does anyone know what it is?
Old May 21, 2009 | 01:12 PM
Deepsouth251's Avatar
Deepsouth251
I'm pretty sure fork oil not suppose to be changed at 1k. If I'm not wrong its not until at least 20k. I don't have access to my service manual right now (its at home im at work)
Old May 21, 2009 | 01:14 PM
1of2's Avatar
1of2
"Moderator"
Here is when Harley suggests:
AT 1,000 MILES / 1,600 KILOMETERS
ITEM SERVICED
PROCEDURE
NOTES
Engine oil and filter
Replace
Oil lines and brake system
Inspect for leaks
Air cleaner
Inspect, service as required
Tires
Check pressure, inspect tread
Wheel spokes
Check tightness
1,6
Primary chaincase lubricant
Replace
Transmission lubricant
Replace
Clutch
Check adjustment
Drive belt and compensator sprocket
Inspect, adjust belt
Compensator sprocket isolators
Inspect for wear
Brake and clutch controls
Check, adjust and lubricate
Jiffy stand
Inspect and lubricate
Fuel lines and fittings
Inspect for leaks
Brake fluid
Check levels and condition
Brake pads and discs
Inspect for wear
Spark plugs
Inspect
Electrical equipment and switches
Check operation
Front fork oil
Replace
1,2
Steering head bearings
Lubricate
Air suspension
Check pressure, operation and leakage
Fuel door, Tour-Pak, saddlebags
Lubricate hinges and latches
Critical fasteners
Check tightness
Battery
Check battery and clean connections
Exhaust system
Inspect for leaks, cracks and loose or missing fasteners or heat shields
Road test
Verify component and system functions
NOTES
1. Should be performed by an authorized Harley-Davidson dealer, unless you have the proper tools, service data and are mechanically qualified.
2. Disassemble, lubricate and inspect every 50,000 miles (80,000 kilometers).
3. Perform annually.
4. Change D.O.T. 4 and flush brake system every two years.
5. Perform at each rear tire change.
6. Not all vehicles are equipped with spoke wheels. Consult appropriate topic in service manual.
Old May 21, 2009 | 01:26 PM
Deepsouth251
What are you riding, from what I understand its a real bitch to change the fork oil on anything with a fairing and thats why the 20k is so costly because of the time it take to change it and it is not included in the price of the 1k unless your dealer is charging between 500 and 600 for the 1k. I did my own 1k service and the service manual said nothing about changing the fork oil on my 09 Ultra. Think about it for a minute, why would the fork oil need changing at 1k if its going to last for the next 49,000 miles.
Old May 21, 2009 | 01:34 PM
dawg's Avatar
dawg
I didn't change mine at 1k. I change mine at 20k. HD says 50k, but I ain't waiting that long. Gets black quick
Old May 21, 2009 | 01:43 PM
Bertk's Avatar
Bertk
The 1K fork oil change must be new for 09. The 08's recommend 50k. After reading this thread I changed the fork oil and upgraded to the SE "Heavy" oil, PN: 99881-87. I would check the 2009 service manual before proceeding. In my case, front end dive was greatly reduced. Ride was improved and the front end wallow was gone. As ease as it was, I would never let it go more than 10K.
Old May 21, 2009 | 01:44 PM
1of2's Avatar
1of2
"Moderator"
I also have an 09 Ultra. I got this info from the Harley site.
That is why I asked. Doesnt make sense. Maybe they have lighter break in fluid in there or feel that during the initial break in it get unusually dirty. Not sure but I was hoping someone knew for sure.
Old May 21, 2009 | 01:50 PM
Deepsouth251
I get off work at 6pm and will be able to say for sure after I get home.
Old May 21, 2009 | 01:58 PM
Bertk's Avatar
Bertk
ITEM SERVICED PROCEDURE NOTES
Front fork oil Replace 1,2
NOTES
This indicates the first fork oil change is at 50K, and should be performed by HD. The service manual method for changing the fork oil includes removing the legs. This is not necessary as long as the exact amount of oil is added to each leg as describe here. Just make sure the numbers are the same for the 09's.
Old May 21, 2009 | 02:12 PM
Deepsouth251
I was so intriqued with this question because things were just not adding up. It makes no sense to think that the fork oil needs changing at 1k but not need changing again until 50,000 so I called the local dealer service dept and they told me it was 50,000 and not 1,000. I also asked the question of didn't it use to be 20,000 and he told me that changed to 50,000 in 2005.
