...follow the link in iclick's post for changing your fork oil. a lot of us have gone with the se heavy (which is a 20wt) and are extremely pleased with the results. others don't want to go quite as heavy so they mix type e (10wt) and se heavy 50/50 which will give you a 15 wt. also i think belray actually does sell 15 wt. whichever way you go, i guarantee you that it will be better than whats in there now.
try that first. if you don't like it, what are you out? nothing really, because it will be better than stock. but if it isn't enough for you, then you can start spending your hard earned money on other things....
Sound and simple advice is always hard to beat! Like Skratch says, do this simple easy trick and most folks are quite happy with the results.
The Race Tech forks with dual cartridges and Gold Valve Emulators work great on my bike.
I liked them over the stock set-up, but they feel like crap, now that I put the Ohlins shocks on it. I had Progressive 430 (11-1/2") shocks, went back to 12" and set the sag correctly and now the forks feel harsh. I'm going to get rid of them, I'm not impressed with Race-Tech stuff. JMO
Just sounds like your front end needs to be re-synced with the new shocks on the back. Race tech could probably give you some tech advice (lighter fork oil, different preload, etc) on how to achieve that. Worth trying seeing how you already have them.
sounds like a bunch of folks spent big money on other things and don't want you to be happy with your setup unless you spend big money too.
I think that's a good observation. Use both brakes and it'll probably stop better than waiting till the last second then cinching down on that front brake until your knuckles turn white.
Thanks for the responses. I think I will start with changing the fork oil to the heavy weight and see how that works.
One item of note, from many years of sport bikes, the front brake is used the most and the rear only for panic stops. I am trying to adjust since it has ABS to using both brakes at once, but a hard habit to brake. The concept of using the rear brake only if you want to have problems...but trying to learn to appreciate the ABS.
Heavier fork oil will lessen fork dive but it can also make the ride harsher. Before you make any changes, why not practice using the front brakes as you always have, while simultaneously apply the rear brake to minimize the fork dive. This will work!
This doesn't ring true with anything I've ever done. The rear brake is usually applied first and then the front brake is applied. I never rode a sport bike but I rode plenty of bikes. No wonder you get fork dive. I thought there was something wrong with your technique and now I know.
