Stage 1 or .......Help!!
Old Jun 1, 2009 | 01:55 PM
iclick's Avatar
iclick
Originally Posted by jorswift
How do I go about doing checking the records online?
I just tried it with my VIN# and it showed nothing. Of course I've never had it in for service since I do all my own work, but if it showed the history it would've produced one warranty job I had the dealer perform. So, you may need to take the bike to the dealer and have them determine the state of the ECM. Of course they likely won't do it free.
Old Jun 1, 2009 | 03:02 PM
jorswift's Avatar
jorswift
Does it matter what stage the ECM is in if I have a PCIII ?
Old Jun 2, 2009 | 06:39 AM
jorswift's Avatar
jorswift
Here are some pics I took of my setup.
Old Jun 2, 2009 | 09:39 AM
jorswift's Avatar
jorswift
Some reason pics won't load
Old Jun 2, 2009 | 09:55 AM
jorswift's Avatar
jorswift
OK, here are the pictures I took last night of my Air Cleaner setup. Thanks.
Attached Thumbnails Stage 1 or .......Help!!-1.jpg   Stage 1 or .......Help!!-2.jpg   Stage 1 or .......Help!!-3.jpg
Old Jun 2, 2009 | 10:06 AM
jmeyer58's Avatar
jmeyer58
That looks like the older Stage one HD air filter set up. I have the same one on mine. Do you have a Tach for the bike? If so, see if it will run to 6,200 rpm or if it stops at 5,700. If it will go to 6,200 it has the stage one download.
Old Jun 2, 2009 | 10:16 AM
jorswift's Avatar
jorswift
Nope no tach. Will it matter if I have a stage 1 download with a pc3?
Old Jun 2, 2009 | 03:18 PM
jorswift's Avatar
jorswift
Any one know what this set us from the above pics?
Old Jun 2, 2009 | 03:26 PM
themensh's Avatar
themensh
By the looks of your air filter, it appears to be a screamin' eagle or a similar make.
Lookslike you have stock lifter tubes....so that most likely means your cams are stock and also do not have any other mods to it (cam gears....).
I do not know if PCIII cam be added while a stage one download is installed.
But I would almost bet that if pipes and a/c changed.......a person would go ahead and upgrade the ECM. Have you looked to see if a PCIII or similar is installed?
Chuck
Old Jun 2, 2009 | 03:28 PM
jorswift's Avatar
jorswift
I installed a pc3.
