Strapping down in toy hauler
Old Jun 2, 2009 | 05:57 PM
papa_freeman's Avatar
papa_freeman
Default not a tourer, but...
Originally Posted by soos
Use a wheel chock and geez, stay off the handlebars.
I'm assuming that it is not a good idea to winch down on the bars due to the continuous compression of the front suspension???? If not, please enlighten me...
Also, my buddy has a new CVO w/Springer front end--- saw him tying down the bars real tight --- I aked him about that not being good for the suspension-- he said it was no problem--- I didn't like the look of it, especially for a LONG trip---
Yes? No?
Old Jun 2, 2009 | 06:32 PM
puma's Avatar
puma
When I brought my '99 FLHT home the dealer told me to put the sraps around the fog/signal light bar, that's the only place I've every tied it to since & I've never had a problem.
Old Jun 2, 2009 | 06:44 PM
Fewe's Avatar
Fewe
I absolutely recommend getting a wheel chock. I have a Condor with the trailer attachment accessory. I would never go back to "winging it" after using the Condor. Makes trailering easier and more secure. One person can drive into the wheel chock, get off and tie down with no problem. I bought mine last summer before a 1,100 mile trip with my Ultra on a trailer based on recommendations from this here forum. There were a lot of threads about how to best tie down then too. Lots of photos of different methods of securing with tie downs. I attached the trailer anchors forward and slightly out from my passenger floorboard brackets. To tie down, I drove into the chock and used two ratchet straps, one for each side, from the passenger floorboard brackets to the anchors on the trailer. I would check the bike at every fuel stop just to be sure but the bike never moved.
Old Jun 2, 2009 | 07:24 PM
soos's Avatar
soos
Yes? No?
There are 2 schools of thought on securing the front end. One is to compress the front shocks into a wheel chock. This is done by securing above the front forks at or near the triple tree or to the engine guard and ratcheting the front end down. If you don't compress the front shocks fully, you will still have compression travel caused by by vehicle movement. This will cause strap shock which is the snapping of the strap every time the front forks dip and cause slack in the strap. This situation could cause the straps to loosen or fail. It is recommended to place a block under the forward frame and cinch the front forks down until the frame contacts the block. I prefer securing on each fork where the front fender is fastened. I ratchet the front end this way into a chock. This allows the bike to ride its own suspension.
Most handle bars are 1" diameter with a .04 to .06 wall thickness. It is held in place by a clamp. Putting stress on this "tube" could cause it to bend or rotate downward allowing your straps to loosen, which is a recipe for disaster.
The only time my scoot sees the inside of the trailer is when I have to take it in for service that I can't do myself. Most times I loan it out.
Old Jun 2, 2009 | 07:32 PM
Raventhik's Avatar
Raventhik
Thanks for all the replys and pics.
Anyone ever block the frame and pull against it?
Old Jun 2, 2009 | 07:38 PM
clanker24's Avatar
clanker24
I use a wheel chock, the kuryakyn tie down brackets, a block under the frame & stabilize it off the floorboard brackets or the rear tour pack bracket. Never had a problem.
Old Jun 2, 2009 | 07:49 PM
pbsdaddy's Avatar
pbsdaddy
Chocking the front wheel is an absolute. If you don't the wheel can turn to one side or the other. If this happens, the overall length of the bike, as it is tied, shortens. That will allow your other straps to go slack and your bike to rock around. If the bike starts to rock, disaster is soon to follow.
FIW, I have always used to bars to tie down the frontend. Maybe I've just been lucky, but I've never had a problem. And I always use 6 straps to tie it. 2 on the bars. 2 on the rear, pulling out and forward and 2 more on the front pulling out and to the rear.
I've seen straps slip, break, tear and apparently stretch. I've seen hooks break, tie downs break and bend, eye hooks pull through the flooring, etc. A couple extra straps and a few more minutes are nothing compared to the price of a bike.
Old Jun 3, 2009 | 08:53 AM
bunkerbeer's Avatar
bunkerbeer
What ever you do, DONT USE THE BARS!!!
Old Jun 3, 2009 | 10:11 AM
Leftcoaster's Avatar
Leftcoaster
I've towed motorcycles for 30+ years and have piled up thousands of miles with bikes in and on trailers. Tying down using the handlebars has never caused any problems and this includes HarleyDavidsons. When trailering Eglides (or anything else) I use a wheel chock (Pingel) and nylon loops (at the bars) with ratchet straps and collapse the forks far enough that a large bump will not let the straps come loose. I also tie down the rear of the bike on long trips. Tying to the bars is not a problem when done properly and it doesn't ruin the rubber bushings. What IS dangerous is tying to the passing light bar or crash bar. The reasons for avoiding these are obvious (or should be). I like the idea of the self clamping wheel chocks and may invest in them but I would back them up with straps in any event.
Old Jun 3, 2009 | 10:49 AM
keltonkrew's Avatar
keltonkrew
When I tie the RK and Heritage in my trailer I basically have done the same....I tied to the bars, compressed the front suspension down enough that no travel. I have fur lined straps around the bars. I also put 2 straps at rear on the rear bag guards...Have towed about 5K miles alltogether this way on many trips and have never had an issue. I tied up high for balance..you tie too low, the top is still heavy and can sway (at least my mind tells me that).
