Changing oil filter
Old Jun 4, 2009 | 11:57 AM
BiggDogg's Avatar
BiggDogg
I know i have a sportster but I just use plenty of bunched paper towels under the filter as I twist it off and remove it quickly
Old Jun 4, 2009 | 11:58 AM
capt_caveman's Avatar
capt_caveman
I saw a tip someplace that I haven't tried on the bike but worked great on the car. Use a large ziplock baggie. Loosen the filter then slide the baggie over the filter and up against the mount. Unscrew the filter and it's already in the bag to be sealed and disposed. Like I said, it worked great on the car filter but I haven't had a chance to try it on the bike yet. Just a thought.
Old Jun 4, 2009 | 12:03 PM
langhammx's Avatar
langhammx
Default filter
I made a makeshift catch similar to the 2-liter bottle trick, but before I unscrew the filter, I use a screwdriver and poke a hole on the end of the filter, towards the bottom to get all the oil out. It still drips a little but most of the oil drains out the hole.
Old Jun 4, 2009 | 12:31 PM
chipishere's Avatar
chipishere
+1, another hole in the top relieves the vacuum buildup and it drains a little faster. I took an old POS phillips screwdriver to the bench grinder and sharpened it up just for this. Use it on the cars too.
Old Jun 4, 2009 | 06:04 PM
tennessee streetglide's Avatar
Thanks for all the advice i guess i will try one of them on my next weekend i get off.
Old Jun 4, 2009 | 06:11 PM
cap5369's Avatar
cap5369
Originally Posted by GzrGlide
I use a pop bottle , with the bottom cut off. I have one of those filter caps that fits over the filter and fits onto a ratchet drive. Slide the bottle over the filter as far as it will go and take the bottle cap off. Then using a 12 inch extension on the ratchet, put it thru the bottle opening and into the "filter cap". Start loosening the filter and once its off, pull the extension off, put the bottle cap back on ( to catch the oil ) and let it sit while you get ready to put the new oil in the bike. When you're ready, pull the bottle out with the filter and oil in it and dispose of them properly.
No mess, and has worked for me for over 5 years.
It is tight getting the bottle in and out because of the shifter, but it is doable.
+1 do the same thing. Learned it right off the forum.
Old Jun 4, 2009 | 06:49 PM
garyhendley's Avatar
garyhendley
tried the 2 litre bottle it was a mess so i bought a oil changing pan from j&p cycles
works great about $20.00-ride safe
Old Jun 4, 2009 | 11:23 PM
rdam's Avatar
rdam
Originally Posted by Jinks
I bought a roll of Heavy Duty Reynolds Wrap years ago. I tear off a piece big enough to fold for two layers, make a narrow spill-way that slips under the filter. When you loosen the filter a little oil will drip in the spill-way & run to a catch pan I place at the end. After the filter comes off I wipe the filter mount & fold up the Reynolds Wrap. No drip, no mess. One box of that stuff has lasted for years..........
+1.... Can't remember where I learned it, but it makes clean up easy!
Old Jun 6, 2009 | 12:26 AM
emwolb's Avatar
emwolb
if you use an awl, sorta like an icepick but thicker , you can pop a hole in the lower corner of the filter, and one up near the center of the end for venting, and most of the oil will drain out of that lower corner hole rather than all around the filter. an old trick, but gravity is pretty old and still works the same way.
Old Jun 6, 2009 | 12:29 AM
emwolb's Avatar
emwolb
tennessee streetglide, if there wasn't enough help with your oil change questions, there is also a section right below the touring section named "oil and oil related products" you can read there.
