Changing oil filter
Old Jun 6, 2009 | 08:52 AM
dirtdobber's Avatar
dirtdobber
I use the pop bottle. I got a long drill bit to put 2 holes in it. 1 in the center (for air) 2nd at the bottom (lets the oil drain). I run it through the top of the bottle and put the cap back on. Then I pour the oil out of the bottle and use my filter wrench. The filter wrench hangs on on the engine case ( I have an oil cooler) with the pop bottle in place and the filter wrench inside it doesn't hang when removing it.
Old Jun 6, 2009 | 09:01 AM
beary's Avatar
beary
The foil trick worked great on my 02, but not the 09. No I use the plastic bag trick and it works ok. None this ideas work as good on my 09 as the foil worked on the 02.
Baeary
smokingjoe
Milwaukee Eight (M8)
37
Jul 24, 2017 10:44 AM
deadman77
Oct 18, 2015 06:45 AM
Timpechos
Jul 5, 2013 10:14 AM
RoadKingHellas
Feb 10, 2013 12:24 PM
65_glide
Panhead
Sep 24, 2010 12:08 AM
