Using a radar detector
Old Jun 7, 2009 | 09:18 AM
Sharknose's Avatar
Sharknose
Default Using a radar detector
I have a Whistler Pro 73 radar detector that I would like to use on the bike but it doesn't produce enough volume to overcome the road/wind/exhaust noise. There is no external speaker jack. Has anybody else had this problem with a detector and found a way to overcome it?
[edit: something like this would be perfect if it didn't require a jack]
Old Jun 7, 2009 | 09:47 AM
e6fmf's Avatar
e6fmf
Default Radar Detector
Sir,
Re: Your radar detector.
When it activates, it's all over but the shouting. I know what I speak of.
Good luck.
Old Jun 7, 2009 | 09:51 AM
Sharknose's Avatar
Sharknose
Originally Posted by e6fmf
Sir,
Good luck.
Thank you, but that wasn't my question. I don't want this thread to go off on a "detector-yes or no" tangent. There are plenty of those elsewhere.
Old Jun 7, 2009 | 09:56 AM
dklanecky's Avatar
dklanecky
The Valentine One has an output jack for an ear speaker and you can also buy a much smaller remote piece that can be mounted almost anywhere so it stays in your line of sight. The remote piece maintains all the functionality of the main unit. (It's also ~$400 for main unit and the speaker and remote are extra.)
Old Jun 7, 2009 | 10:13 AM
blkjac's Avatar
blkjac
Default Radar
I have one of these. Works great.
http://www.motorcycleradar.com/radar_screamer.htm
Old Jun 7, 2009 | 10:37 AM
Skulmn's Avatar
Skulmn
I use one of these with a valentine and it works great...
This is what you want.
Old Jun 7, 2009 | 11:29 AM
marcparnes's Avatar
marcparnes
Actually, it doesn't. In order to use an earphone with the Valentine you have to buy their audio adapter. The small hole on the side of the V1 that looks like an earphone jack is really just a vent hole to the speaker inside. Valentine is the only one that makes you buy something else in order to use an earphone. $50 extra, BTW.
Marc
Old Jun 7, 2009 | 02:48 PM
ktm990's Avatar
ktm990
google: Legal Speeding. They have just what you need and are focused on motorcycle solutions. Check out the head-up display for the Passport and Valentine so you can hide to detector. You also want to buy a detector that does not emit radiation that the cops can pick up in states like Virginia and Canukistan. And get a book call The Speeder's Guide to Avoiding Speeding Tickets. Written by a former New York State Trooper it will help a lot.
Old Jun 7, 2009 | 02:53 PM
Sharknose's Avatar
Sharknose
That's what I linked to in the original post but the problem is that I don't have an audio out jack. I need something--possibly homebrew--that will work with my Whistler. I've added the Radio Shack siren to my security system...I whipped up a pushbutton on my instrument bezel that opens my garage door...Now I'd like to get the soldering iron out and wire up some sort of louder alarm.
Old Jun 10, 2009 | 03:06 PM
Sharknose's Avatar
Sharknose
Solved my problem for less than $20. I went to a local electronics shop and bought a 1 watt audio amp kit, a small (1 1/2" or so) speaker and a box just big enough to house it. I'll just drill a tiny hole in the detector's case big enough for the speaker wire to pass through, and connect the input of the amp to the speaker wires. A magnet inside the bottom of the box will allow me to stick it to anywhere metallic and 1 watt is much more sound than my detector makes on its own.
Hawkguy
Audio Systems
Jun 29, 2016 10:08 PM
stevepacman
May 30, 2013 08:11 PM
theoldguy
Jul 24, 2007 09:37 AM
kwgrimes
Mar 2, 2007 01:31 AM
Harley Al
Harley Davidson Videos
Feb 10, 2006 12:27 AM
