Guys..... Need HELP!
Have a 2007 Streetglide and when I went for a ride this weekend I found out my Headlight, Passing Lamps,Crashbar driving lights, Brakelights and Dash panel lights were not working..... I only checked the fuse so far did not have time to get into it and they were good the only things that work are the turn signals,Flashers,the spoiler,Gauge lights and the brake light on the tourpak spoiler.....
Any suggestions.....
John
If it is not the fuse look under the seat and there is a few plugs on the wiring harness up close to the tank I think there a 3 of them and if they are ok look behind the fairing at the plugs and make sure they are plugged in good also while you are looking make sure there are none of those wires are pinched also there are some relays around the battery too. Thats the only thing I can think of right now. Hope you find out what is wrong
Thanks......Off from work for the next few days so I will look into that....A friend of mine also told me to check behind the fairing because I just had my fairing brackets replaced at a dealer and they mentioned that they could have pinched a wire......
