Shock Pressure question
Old Jun 10, 2009 | 04:47 PM
twodollarbill's Avatar
twodollarbill
Originally Posted by bdp
Yes, just plan on pumping for an hour.
Now that's funny!!!!!
I pump my shocks up to 40psi when pulling the trailer.
Old Jun 10, 2009 | 06:03 PM
ballpeen's Avatar
ballpeen
Originally Posted by tpmurray
While you are checking your air line connections you could cut 1/8" off the lines using a new razor blade - cut as square as you can (perpendicular to the line).
Very good suggestion here........ I had to do this to one of my lines when it was new.. TIm
Old Jun 10, 2009 | 06:52 PM
txfxstrider's Avatar
txfxstrider
Originally Posted by HarleyWood
If your pump is losing air when you connect it or remove then its defective.
A zero loss pump should have zero loss. i have one and it works, no air loss.
+1
Old Jun 10, 2009 | 07:31 PM
Hogwallop's Avatar
Hogwallop
I had an air loss issue with mine and found the schrader valve stem inner core was slightly loose. Used an insert tool and tightened, about 1/4 turn which stopped the air loss. Was loosing a couple pounds a day until i made the adjustment.
Old Jul 26, 2009 | 02:31 PM
skcm2006's Avatar
skcm2006
Have not come back to the forum for an update - sorry about that. I did what Hogwallop suggested and tighten the schrader valve. I turned it 1//8th of a turn and not only have the shocks NOT lost pressure the air "pssst" from the air pump is about gone....
Thanks Hogwallop!
Old Jul 26, 2009 | 06:53 PM
emwolb's Avatar
emwolb
i ride with 20 psi in the streetglide. i weigh about 200# and it works just fine. if you're losing air, it wouldn't take a rocket surgeon to figure out where from.
RogFel
2014-2024 Touring Models
Oct 5, 2015 09:55 AM
Orange Crush 2011
Jul 29, 2011 03:03 PM
Dax4800
Apr 25, 2009 11:16 AM
cfs754
Apr 6, 2009 06:48 PM
dog155
Sep 21, 2007 07:18 AM
