New Grips
Old Jun 9, 2009 | 12:15 PM
Cheeze's Avatar
Cheeze
Default New Grips
Is changing the grips on my 09 Ultra hard to do? Any advice before i dive in?
Old Jun 9, 2009 | 12:43 PM
UltraTheo's Avatar
UltraTheo
Simple as pie. No problems at all, should take you about ten minutes.
Old Jun 9, 2009 | 01:37 PM
BigDaddyMike's Avatar
BigDaddyMike
10 minute job if you stop for a bathroom break!
Old Jun 9, 2009 | 01:40 PM
Cheeze's Avatar
Cheeze
Your seat looks like the Mustang Solo with backrest I just ordered....i ordered the fender bib also. You like it?
Old Jun 9, 2009 | 01:41 PM
CruzN's Avatar
CruzN
Default 10 minute ??
I have been looking at replacing my stock grips.
I was worked about the 09's throttle by wire rather then cable.
Is it that quick ?
Any problems with the throttle getting stuck or hard to twist?
Old Jun 9, 2009 | 01:48 PM
BigDaddyMike
I LOVE it! Have the passenger pillion also. My second one. Also have a C&C solo for sporting around. Love it too!
Old Jun 9, 2009 | 05:00 PM
jkoch09ultra's Avatar
jkoch09ultra
On the throttle side mark the h-bars with a sharpie so that you can align the back in the same place. Do not take it completely apart. I just loosened up my screws on the brake side just enough to get the old part out and the new grip in. Tighten back down in the same position or the brake light will stay on. That is what happened to me. Just loosen the clamp again and move it to the propper place and the brake light will work correctly again. Left side is easy. Cut off and glue the new one on. Not hard except keeping the right side in the correct alignment. Check your brake light to make sure that it goes out when hand brake is not applied when you are finished.
bob5800
Feb 12, 2012 11:52 AM
roadking2005sg
Mar 26, 2011 05:25 PM
nickmack
Feb 24, 2010 11:18 AM
Scubamike
Jul 30, 2009 07:52 PM
kelticknotts
Aug 4, 2007 07:24 AM
