what can i expect?
Old Jun 10, 2009 | 01:19 PM
Rock Chalk's Avatar
Rock Chalk
Originally Posted by vinnieee
If you don't want to install this yourself I would recommend that you take it to a shop that uses and tunes with the Power Commander.
Sounds like the thing is pretty much a no brainer to install and it comes from fuel moto ready w/ all the information already loaded...right?
Also - does this think void the warranty....or do you just take if off if you have problems and they never know?
Old Jun 10, 2009 | 03:09 PM
nytryder's Avatar
nytryder
I chose the SERT and am more than pleased. A stage 1 download will work also. Runs about 150.00 and has no effect on warranty.
Old Jun 10, 2009 | 03:50 PM
_Flea_'s Avatar
_Flea_
I had a PCIII on my bike. It was one of those "good enough to get the job done" products. I didn't realize how much I was sacrificing with the Power Commander until I had some motor work done and switched to a TTS MasterTune.
PCIII from Fuel Moto
Best gas mileage - 45 mpg on interstate right after installing
Average gas mileage on interstate - 40-43 mpg
Average gas mileage in city - 35-38
TTS Mastertune & tuned by Skips Speed and Custom Cycles
Best gas mileage - 49.8 mpg on interstate
Average gas mileage on interstate - 45-49
Average gas mileage in city - 43-45
And I can get about the same mileage in the mountains as I do on the interstate.
Mods done to bike:
Rinehart True Duals
Arlen Ness Big Sucker
107 kit by Skips Speed & Custom Cycles (115 hp, 128 tq)
Old Jun 10, 2009 | 04:03 PM
emwolb's Avatar
emwolb
i installed the pcv on my 08 sg, and am happy with it. you no longer have to wait for the electronics cycle through till the yellow circled light goes off on your dash, you just turn on the ignition and hit the starter. it does richen up your fuel mixture, or what is also known as the air to fuel ratio. it cools down the engine significantly, and there is more power/torque from idle all the way through the rev range. it's easy to install. the hardest thing is removing the battery from your bike. great instructions, and if you get it from fuelmoto, those guys are great to deal with. alternative mapping is available through fuelmoto should you decide to change anything like changing your motor to a 103 or any other changes. the map it will come with was designed for your combination, at fuelmoto they set it up for your exhaust, intake system, etc. it's cheapest at fuelmoto too. you can also put in two different maps, using a toggle switch to change maps. one more feature you may or may not want, is the auto tune module. where you replace the 02 sensors with the power commander ones, and then the pcv will tune as you ride. if you want that extra two ft lbs of torque or the last two or three horsepower, you can get it dyno tuned too. well, i've given you all the information i can, as that's all i know about it, other than i feel it's a great product. it doesn't require any cutting of a harley harness, it piggybacks onto your ecm, so it can be removed if you feel the need. a quality item for just under three hundred bux. hope this helped.
Old Jun 10, 2009 | 09:24 PM
Rock Chalk's Avatar
Rock Chalk
so, are you saying that if i've got a stage 1 download that a power commander won't add anything? i had the ecm reflash done when the exhaust and breather were installed.
man, it sucks being dumb
Old Jun 10, 2009 | 10:56 PM
nytryder's Avatar
nytryder
If it helps at all it will be insignificant.
Old Jun 11, 2009 | 07:40 AM
FLHTCU Owner's Avatar
FLHTCU Owner
The SERT (Scremin Eagle Race Tuner) is HD's version of the PC tuner. Recommend getting one or the other.
Old Jun 11, 2009 | 07:50 AM
budnlucy's Avatar
budnlucy
I have the pcv, very happy with it. got everything from fuel moto. Plug and play.
Old Jun 11, 2009 | 08:30 AM
skydrifter's Avatar
skydrifter
You can expect a bill for about 1800.00
Srowe
Feb 6, 2013 02:17 PM
tammychad
Apr 1, 2011 08:50 PM
dbird08
Apr 20, 2010 11:28 PM
ACRoadKing
Aug 16, 2009 08:27 AM
DC2009EGUC
Jan 25, 2009 09:10 PM
